01-10-2020 07:16 AM
I bought cisco ISR 931 router recently and struggled to setup 2 IPSEC tunnels. The router is put as edge router that directly faces internet with one fixed IP and connects to 2 remote sites with 2 fixed IPs for the 2 IPSEC tunnels.
To begin with, I create 2 vlans with vlan interfaces as below.
interface Vlan1
ip address 10.249.102.193 255.255.255.192
ip pim sparse-mode
ip nat inside
ip virtual-reassembly in
interface Vlan2
ip address 172.28.207.177 255.255.255.240
ip pim sparse-mode
ip nat inside
Then, the Gigabit WAN interface facing internet with fixed IP (x.x.x.x).
interface GigabitEthernet4
ip address x.x.x.x 255.255.255.252
ip nat outside
duplex auto
speed auto
Then, NAT 2 vlans to access internet,
access-list 10 permit 10.249.102.192 0.0.0.63
access-list 20 permit 172.28.207.176 0.0.0.15
ip nat pool INTERNET x.x.x.x x.x.x.x netmask 255.255.255.252
ip nat inside source list 10 pool INTERNET overload
ip nat inside source list 20 pool INTERNET overload
Then, define 2 crypto isakmp policies.
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp policy 2
encr 3des
hash md5
Then, define the pre-shared keys.
crypto isakmp key SECRET_KEY address y.y.y.y
crypto isakmp key SECRET_KEY address z.z.z.z
Then, define ipsec transform-set.
crypto ipsec transform-set setvpn esp-3des esp-sha-hmac
mode tunnel
crypto ipsec transform-set cmevpn esp-3des esp-md5-hmac
mode tunnel
Then, define the access list for IPSEC tunnels.
access-list 100 permit ip 10.249.102.192 0.0.0.63 69.50.112.0 0.0.0.255
access-list 110 permit ip 172.28.207.176 0.0.0.15 172.19.214.0 0.0.0.255
access-list 110 permit ip 172.28.207.176 0.0.0.15 172.19.215.0 0.0.0.255
access-list 110 permit ip 172.28.207.176 0.0.0.15 10.3.14.0 0.0.0.255
access-list 110 permit ip 172.28.207.176 0.0.0.15 10.3.27.0 0.0.0.255
access-list 110 permit ip 172.28.207.176 0.0.0.15 172.19.7.0 0.0.0.255
access-list 110 permit ip 172.28.207.176 0.0.0.15 10.22.6.0 0.0.0.255
access-list 110 permit ip 172.28.207.176 0.0.0.15 10.22.61.0 0.0.0.255
access-list 110 permit ip 172.28.207.176 0.0.0.15 10.232.6.0 0.0.0.255
Then, define the cryto map with 2 indices.
crypto map CRYTOMAP 1 ipsec-isakmp
set peer y.y.y.y
set transform-set setvpn
match address 110
crypto map CRYTOMAP 2 ipsec-isakmp
set peer z.z.z.z
set transform-set cmevpn
match address 100
Then, apply it to the WAN interface.
ip nat outside
duplex auto
speed auto
crypto map CRYTOMAP
After it is applied, the 1st IPSEC phase 1 is not initiated and the 2nd IPSEC tunnel is UP-IDLE. With debug crypto ipsec on, I can see the following error,
*Jan 10 14:40:57.347: IPSEC: Expand action denied, discard or forward packet.
*Jan 10 14:40:57.347: IPSEC: Expand action denied, notify RP
*Jan 10 14:40:57.347: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
Would someone help give me some hints on what might be going on and how to fix it? what "Expand action denied, discard or forward packet" means? Thank you!
01-10-2020 07:50 AM
in your NAT access lists, you need to deny the traffic that is flowing through the VPNs. Change the access lists as below:
ip nat inside source list 101 pool INTERNET overload
ip nat inside source list 102 pool INTERNET overload
access-list 101 deny ip 10.249.102.192 0.0.0.63 69.50.112.0 0.0.0.255
access-list 101 permit ip 10.249.102.192 0.0.0.63 any
access-list 102 deny ip 172.28.207.176 0.0.0.15 172.19.214.0 0.0.0.255
access-list 102 deny ip 172.28.207.176 0.0.0.15 172.19.215.0 0.0.0.255
access-list 102 deny ip 172.28.207.176 0.0.0.15 10.3.14.0 0.0.0.255
access-list 102 deny ip 172.28.207.176 0.0.0.15 10.3.27.0 0.0.0.255
access-list 102 deny ip 172.28.207.176 0.0.0.15 172.19.7.0 0.0.0.255
access-list 102 deny ip 172.28.207.176 0.0.0.15 10.22.6.0 0.0.0.255
access-list 102 deny ip 172.28.207.176 0.0.0.15 10.22.61.0 0.0.0.255
access-list 102 deny ip 172.28.207.176 0.0.0.15 10.232.6.0 0.0.0.255
access-list 102 permit ip 172.28.207.176 0.0.0.15 any
01-10-2020 08:23 AM
@Georg Pauwen Thank you for your suggestion. I just change it accordingly, the issue is still there with the same error messages as before. Do you have other suggestions? Thank you very much!
01-10-2020 08:54 AM
post the full running configuration (sh run) including the changes you made...
01-10-2020 06:32 PM
@Georg PauwenPlease find the complete config as. thanks alot!
version 15.8
service password-encryption
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 172.28.207.177 172.28.207.179
ip dhcp pool pool1
network 10.249.102.192 255.255.255.192
dns-server 203.80.96.33
default-router 10.249.102.193
ip dhcp pool pool2
network 172.28.207.176 255.255.255.240
default-router 172.28.207.177
ip dhcp pool YASSVR
host 172.28.207.179 255.255.255.240
hardware-address 44a8.4234.0510
ip dhcp pool iDRAC
host 172.28.207.178 255.255.255.240
client-identifier 0144.a842.3405.12
ip name-server 203.80.96.33
ip multicast-routing
no ip cef
no ipv6 cef
license udi pid C931-4P sn PSZ23091D50
license boot module c900 technology-package securityk9
redundancy
encr 3des
encr 3des
hash md5
crypto isakmp key SEC_KEY address y.y.y.y
crypto isakmp key SEC_KEY address z.z.z.z
crypto isakmp keepalive 60 5
mode tunnel
mode tunnel
set peer y.y.y.y
match address 110
set peer z.z.z.z
match address 100
interface GigabitEthernet0
no ip address
no mop enabled
interface GigabitEthernet1
switchport access vlan 2
switchport trunk native vlan 2
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
ip nat outside
duplex auto
speed auto
crypto map CRYTOMAP
interface GigabitEthernet5
ip address dhcp
duplex auto
speed auto
interface Vlan1
ip pim sparse-mode
ip nat inside
interface Vlan2
ip pim sparse-mode
ip nat inside
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 111 pool INTERNET overload
ip route 0.0.0.0 0.0.0.0 b.b.b.b
access-list 111 deny ip 172.28.207.176 0.0.0.15 172.19.214.0 0.0.0.255
access-list 111 deny ip 172.28.207.176 0.0.0.15 172.19.215.0 0.0.0.255
access-list 111 deny ip 172.28.207.176 0.0.0.15 10.3.14.0 0.0.0.255
access-list 111 deny ip 172.28.207.176 0.0.0.15 10.3.27.0 0.0.0.255
access-list 111 deny ip 172.28.207.176 0.0.0.15 172.19.7.0 0.0.0.255
access-list 111 deny ip 172.28.207.176 0.0.0.15 10.22.6.0 0.0.0.255
access-list 111 deny ip 172.28.207.176 0.0.0.15 10.22.61.0 0.0.0.255
access-list 111 deny ip 172.28.207.176 0.0.0.15 10.232.6.0 0.0.0.255
access-list 111 permit ip 172.28.207.176 0.0.0.15 any
control-plane
line con 0
password 7 052B1217294A4A1D4B5546475B5B
login
line vty 0 4
password 7 03244F130E0925581C5948504745
login
transport input none
scheduler allocate 20000 1000
end
01-11-2020 12:39 AM
I have made some changes (marked in bold), try to apply those and check if you have connectvity. If not, shut/unshut interface GigabitEthernet4 and turn on 'debug crypto ipsec' and post the output:
version 15.8
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 10.249.102.193
ip dhcp pool pool1
ip dhcp pool pool2
ip dhcp pool YASSVR
ip dhcp pool iDRAC
ip cef
no ipv6 cef
redundancy
encr 3des
encr 3des
hash md5
mode tunnel
mode tunnel
set peer y.y.y.y
match address 110
set peer z.z.z.z
match address 100
no ip address
no mop enabled
spanning-tree portfast
ip nat outside
duplex auto
speed auto
crypto map CRYTOMAP
ip address dhcp
duplex auto
speed auto
interface Vlan1
ip pim sparse-mode
ip nat inside
interface Vlan2
ip pim sparse-mode
ip nat inside
no ip http server
ip nat inside source list 101 interface GigabitEthernet4 overload
ip nat inside source list 111 interface GigabitEthernet4 overload
control-plane
line con 0
login
line vty 0 4
login
end
01-11-2020 12:48 AM
Also, I am not sure if the Vlans are automatically created when you assign them to the switchports, so you might have to do it manually:
ISR931#conf t
ISR931(config)#vlan 2
01-11-2020 06:14 AM
@Georg Pauwenvlan 2 was automatically created when I create vlan 2 interface by issue interface vlan 2.
01-11-2020 06:18 AM - edited 01-11-2020 06:23 AM
@Georg PauwenI have applied the suggestion in bold and try it again. Unfortunately, the issue persists. Please find the new debug message.
*Jan 11 14:09:26.819: IPSEC: Expand action denied, discard or forward packet.
*Jan 11 14:09:26.819: IPSEC: Expand action denied, notify RP
*Jan 11 14:09:26.819: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
*Jan 11 14:09:35.575: IPSEC(key_engine): got a queue event with 1 KMI message(s)
*Jan 11 14:09:35.801: IPSEC(validate_proposal_request): proposal part #1
*Jan 11 14:09:35.801: IPSEC(validate_proposal_request): proposal part #1,
(key eng. msg.) INBOUND local= x.x.x.x:0, remote= z.z.z.z:0,
local_proxy= 10.249.1.60/255.255.255.255/47/0,
remote_proxy= 10.249.254.1/255.255.255.255/47/0,
protocol= ESP, transform= esp-3des esp-md5-hmac (Tunnel),
lifedur= 0s and 0kb,
spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x0
01-11-2020 06:51 AM
do you have access to the other site, and can you post the config of that site ?
01-11-2020 06:59 AM
The other site is not controlled by me but we used to use linksys router to do the ipsec tunnel and works fine. Therefore, I don't think there is anything wrong on the other site. FYI, this is the modified config (output from show running).
version 15.8
hostname ROUTER_SARYA_00
boot-start-marker
boot-end-marker
enable secret 5 $1$FIbi$LVDQgE7QuEPWnyEAorskK1
enable password 7 1239110F1A0D0810787B757D6362
no aaa new-model
ip dhcp pool pool1
ip dhcp pool pool2
ip dhcp pool YASSVR
ip dhcp pool iDRAC
ip cef
no ipv6 cef
redundancy
encr 3des
encr 3des
hash md5
crypto isakmp key C@fbrk1F address y.y.y.y
crypto isakmp key S@RYAf1ns0ft20191203 address z.z.z.z
mode tunnel
mode tunnel
set peer
match address 110
set peer z.z.z.z
match address 100
no ip address
no mop enabled
no ip address
no ip address
no ip address
ip nat outside
duplex auto
speed auto
crypto map CRYTOMAP
ip address dhcp
duplex auto
speed auto
interface Vlan1
ip pim sparse-mode
ip nat inside
interface Vlan2
ip pim sparse-mode
ip nat inside
no ip http server
ip nat inside source static tcp 172.28.207.179 22 x.x.x.x 22 extendable
ip nat inside source static tcp 172.28.207.179 443 x.x.x.x 443 extendable
ip nat inside source static tcp 172.28.207.178 777 x.x.x.x 777 extendable
ip nat inside source static tcp 172.28.207.178 888 x.x.x.x 888 extendable
access-list 112 deny ip 172.28.207.176 0.0.0.15 10.232.6.0 0.0.0.255
access-list 112 permit ip 172.28.207.176 0.0.0.15 any
control-plane
line con 0
login
line vty 0 4
login
end
01-11-2020 07:14 AM - edited 01-11-2020 07:16 AM
@Georg PauwenAlso, the is the show crypto session output and thank you very much for your help!
Crypto session current status
Interface: GigabitEthernet4
Session status: DOWN
Peer: y.y.y.y port 500
IPSEC FLOW: permit ip 172.28.207.176/255.255.255.240 10.232.6.0/255.255.255.0
Active SAs: 0, origin: crypto map
Session status: UP-IDLE
Peer: z.z.z.z port 500
Session ID: 0
IKEv1 SA: local x.x.x.x/500 remote z.z.z.z/500 Active
IPSEC FLOW: permit ip 10.249.102.192/255.255.255.192 69.50.112.0/255.255.255.0
01-11-2020 08:26 AM
is it possible that the other side uses something different than the default group 1 ? Try the different group options you have. The lifetime might also need to be configured...
encr 3des
hash md5
group ?
lifetime 86400
01-11-2020 08:39 AM
@Georg PauwenThe group is 2 and by default cisco is using group 2 if I remember correct. do you know what the error message mean? BTW, the one CRYTOMAP 2 is working while CRYTOMAP 1 is not.
encr 3des
set peer y.y.y.y
match address 110
01-11-2020 09:40 AM
I am getting a bit confused about the access lists, I think the problem is in that part of your configuration, especially since you say the instance 2 of the crypto map is working, and instance 1 is not. Below are the parts that belong together. Make sure the access lists match as highlighted:
set peer
match address 110
ip nat inside source list 112 interface GigabitEthernet4 overload
set peer z.z.z.z
match address 100
