ISR Boost License Interfaces
aaron.ajello
Is there a limitation on what interfaces are affected by the ISR Boost License?
The product spec refers specifically to the onboard interfaces:
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html#_ftn5
The footnote says: [5] Using onboard Gigabit Ethernet Interfaces
Thanks for your help.
Joseph W. Doherty
That might be due to add-on Ethernet interfaces sometimes having other hardware related performance bottlenecks. I.e. unless the built-in interfaces are used, you might not be able to obtain the performance allowed by the boost license.
