ISR C1111 Failed to boot
Nenday
Hello Community,
lately I did erease the nvram, and my cisco router failed to boot, and even I can't go to romon to boot using usb or TFTP ?
Resetting .......
Rom image verified correctly
System Bootstrap, Version 17.5(1r), RELEASE SOFTWARE
Copyright (c) 1994-2021  by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
C1111-8PLTEEAWA platform with 4194304 Kbytes of main memory
Illegal IP address
  The following variables are REQUIRED for tftp
            IP_ADDRESS: The IP address for this unit
        IP_SUBNET_MASK: The subnet mask for this unit
       DEFAULT_GATEWAY: The default gateway for this unit
           TFTP_SERVER: The IP address of the server to fetch from
             TFTP_FILE: The filename to fetch
autoboot: boot failed, restarting...
how it's possible to deal with this, I'm new in cisco word and I need to boot that router again,
thanks
7 Replies 7
M02@rt37
thank you for your reply,
I'm looking for a way to go to ROMmon mode at the moment, and then I can follow the link,
because when I boot there is no prompt to press anything to interrupt the bootsequence and go for ROMmon,
thanks
It's work, after going to ROMmon menu I add bootfile from Flash and then the router boot again
thanks man
Great news @Nenday
Thanks for your feeback.
Best regards
M02@rt37
@Nenday
You don't have this message during the boot process ?
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
Best regards
Leo Laohoo
Power off the router.
Attach a console cable.
Power up the router.
Post the entire boot-up process so we can see what is going on with the router, particularly the error message(s).
balaji.bandi
