ISR1100-6G, are they only SDWAN or can they be used in standalone mode
collin_n
ISR1100-6G, are they only SDWAN or can they be used in standalone mode like an old fashioned router
balaji.bandi
You can use for normal use, make sure you use the right IOS image for the features to work.
this can be used as branch router ;
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/isr-series-br-platforms-arch.html
BB
Leo Laohoo
Depends on the firmware loaded but 17.X.X can support autonomous or controller mode.
