ISR1100 L2TPv3
Hello
I want extend VLAN over the WAN. The branch router is ISR1100
The ISR 1100 is support L2TPv3?
Giuseppe Larosa
Hello Alejandro,
yes if you have the correct licenses installed
post
show version
show license
Hope to help
Giuseppe
Giuseppe
Claro_Lab#sh license
Index 1 Feature: appxk9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Count: Non-Counted
License Priority: None
Index 2 Feature: securityk9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
Index 3 Feature: ipbasek9
Index 4 Feature: FoundationSuiteK9
Index 5 Feature: hseck9
Index 6 Feature: throughput
Index 7 Feature: internal_service
Claro_Lab#sh versio
Claro_Lab#sh version
Cisco IOS XE Software, Version 16.08.01
Cisco IOS Software [Fuji], ISR Software (ARMV8EB_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.8.1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 27-Mar-18 10:56 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Claro_Lab uptime is 6 hours, 59 minutes
Uptime for this control processor is 7 hours, 1 minute
System returned to ROM by PowerOn at 17:15:02 ARG Thu Aug 15 2019
System restarted at 09:39:26 ARG Fri Aug 23 2019
System image file is "bootflash:c1100-universalk9_ias.16.08.01.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco C1111-4PWA (1RU) processor with 1456982K/6147K bytes of memory.
Processor board ID FGL230112PB
1 Virtual Ethernet interface
7 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
2863103K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
v.snijder
For L2TPV3 you would need to activate the Appxk9 license
