ISR1941 with 3G EHWIC HSPA-U on Telstra not working with ppp
njkroeze
Hi All
I cant get the dialler interface di0 to come up and get an IP address with the carrier. I'm using bits of a working config from an IR809. The only difference is that that router is working with encapsulation slip but the 1941 doesnt support slip on the cellular interface and I've had to use ppp.
I have a chat script, I call the chat script at line0/0/0 (not sure why), also call the same chat script form the di0 interface.
There is a dialler profile in the modem but it shows "Inactive"
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = telstra.corp
Authentication = CHAP
Username: something@something
Password: correctpassword
* - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
Inactivity Reason = Normal inactivate state
Not sure where the problem is, any help would be greatly appreciated.
router#sh ip int br
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 10.65.72.53 YES DHCP up up
GigabitEthernet0/1 unassigned YES NVRAM administratively down down
ATM0/1/0 unassigned YES NVRAM administratively down down
Ethernet0/1/0 unassigned YES NVRAM administratively down down
Cellular0/0/0 unassigned YES unset down down
Cellular0/0/1 unassigned YES unset down down
Dialer0 unassigned YES NVRAM up up  (When its working I get an IP address here from Telstra)
router>en
router#sh cel 0/0/0 radio
Radio power mode = ON
Current Band = WCDMA 850, Channel Number = 4412
Current RSSI(RSCP) = -68 dBm
Current ECIO = -0 dBm
Primary Scrambling Code = 0x11A
Number of nearby cells = 1
Idx PSC (Primary Scrambling Code)
1 282
Band Selected = Auto
Cell 1
RSCP = -64 dBm, ECIO = -4 dBm
router#sh run
Building configuration...
Current configuration : 1908 bytes
! Last configuration change at 05:26:00 UTC Tue Apr 16 2019
version 15.6
hostname router
boot-start-marker
boot system flash:c1900-universalk9-mz.SPA.156-3.M6.bin
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
chat-script gsm "" "AT!CALL1" TIMEOUT 30 "OK"
license udi pid CISCO1941/K9 sn FGL181121BE
redundancy
controller Cellular 0/0
controller VDSL 0/1/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/1/0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0/1/0
no ip address
shutdown
interface Cellular0/0/0
no ip address
ip access-group 1 out
ip virtual-reassembly in
encapsulation ppp
dialer in-band
dialer pool-member 1
async mode interactive
interface Cellular0/0/1
no ip address
encapsulation ppp
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string gsm
dialer persistent
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer0
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
transport input all
rxspeed 7200000
txspeed 5760000
line 0/0/1
no exec
rxspeed 7200000
txspeed 5760000
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
try and add the lines in bold:
interface Dialer0
encapsulation ppp
dialer pool 1
dialer-group 1
dialer string gsm
dialer persistent
no ip http server
dialer-list 1 protocol ip permit
Also, try the chat script below:
chat-script gsm "" "ATDT*98*1#" TIMEOUT 30 "CONNECT"
7 Replies 7
interface Dialer0
encapsulation ppp
dialer pool 1
dialer-group 1
dialer string gsm
dialer persistent
no ip http server
If the cellular interface and the dialer interface are using ppp should there not be some authentication commands (probably chap)? If you run debug for ppp what output do you get?
Rick
Rick
Hi Richard
It is using chap authentication but the commands are not in the dialer interface, although I did try them there, they are currently in the dialer profile in the modem. I can see them with a sh cel 0/0/0 all.
Cheers
Nathan
I've checked and the username and password in the dialler profile are correct.
Also tried putting the ppp username and ppp password commands directly on di0 but this didnt help.
This is what i'm getting at the console:
*Apr 16 23:05:06.723: %LINK-5-CHANGED: Interface Cellular0/0/0, changed state to reset
*Apr 16 23:05:06.723: %DIALER-6-UNBIND: Interface Ce0/0/0 unbound from profile Di0
*Apr 16 23:05:11.723: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to down
*Apr 16 23:05:23.775: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to up
*Apr 16 23:05:23.775: %DIALER-6-BIND: Interface Ce0/0/0 bound to profile Di0
*Apr 16 23:05:23.775: Ce0/0/0 PPP: Using dialer call direction
*Apr 16 23:05:23.775: Ce0/0/0 PPP: Treating connection as a callout
*Apr 16 23:05:23.775: Ce0/0/0 PPP: Session handle[E400006E] Session id[110]
*Apr 16 23:05:25.847: %LINK-5-CHANGED: Interface Cellular0/0/0, changed state to reset
*Apr 16 23:05:25.847: %DIALER-6-UNBIND: Interface Ce0/0/0 unbound from profile Di0
*Apr 16 23:05:30.847: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to down
*Apr 16 23:05:42.895: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to up
*Apr 16 23:05:42.895: %DIALER-6-BIND: Interface Ce0/0/0 bound to profile Di0
*Apr 16 23:05:42.895: Ce0/0/0 PPP: Using dialer call direction
*Apr 16 23:05:42.895: Ce0/0/0 PPP: Treating connection as a callout
*Apr 16 23:05:42.895: Ce0/0/0 PPP: Session handle[F000006F] Session id[111]
*Apr 16 23:05:44.959: %LINK-5-CHANGED: Interface Cellular0/0/0, changed state to reset
Also changed to different sim and am getting the same result, so it appears the carrier is rejecting my connection attempts.
It is not clear from the log messages that you post whether the problem is still with authentication or whether the problem has shifted to something else. If you run the debug again what output are you getting?
Rick
Rick
Hi Georg
I inserted the first two suggestions but nothing happened until I changed the chat script.
Now the cel0/0/0 and di0 interfaces are flip flopping states, which is a marked improvement to what I had before.
I turned ppp authentication debugs on also (Thanks Richard) and I can see that chap auth is failing.
I'll tripple check my username and password are correct and report back.
Thanks for the help!
*Apr 16 22:31:37.347: %DIALER-6-UNBIND: Interface Ce0/0/0 unbound from profile Di0
*Apr 16 22:31:42.347: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to down
*Apr 16 22:31:54.395: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to up
*Apr 16 22:31:54.395: %DIALER-6-BIND: Interface Ce0/0/0 bound to profile Di0
*Apr 16 22:31:56.415: %LINK-5-CHANGED: Interface Cellular0/0/0, changed state to reset
*Apr 16 22:31:56.415: %DIALER-6-UNBIND: Interface Ce0/0/0 unbound from profile Di0
*Apr 16 22:32:01.415: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to down
*Apr 16 22:36:02.395: Ce0/0/0 PPP: Using dialer call direction
*Apr 16 22:36:02.395: Ce0/0/0 PPP: Treating connection as a callout
*Apr 16 22:36:02.395: Ce0/0/0 PPP: Session handle[19000024] Session id[36]
*Apr 16 22:36:02.407: Ce0/0/0 PPP: No authorization without authentication
*Apr 16 22:36:02.407: Ce0/0/0 CHAP: I CHALLENGE id 1 len 35 from "UMTS_CHAP_SRVR"
*Apr 16 22:36:02.407: Ce0/0/0 PPP: Sent CHAP SENDAUTH Request
*Apr 16 22:36:02.407: Ce0/0/0 PPP: Received SENDAUTH Response FAIL
*Apr 16 22:36:02.407: Ce0/0/0 CHAP: Unable to authenticate for peer
*Apr 16 22:36:02.407: Ce0/0/0 PPP: Sending AAA radius abort
