06-21-2020 04:48 AM
when the dialer up again , the lan can't access the internet . when the dialer is down ,the lan can access the internet
config:
Building configuration...
Current configuration : 44882 bytes
! Last configuration change at 17:55:52 CST Sun Jun 21 2020 by cisco
version 16.9
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname ciscoRT
boot-start-marker
boot system bootflash:isr4300-universalk9.16.09.04.SPA.bin
boot system bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging buffered 64000
enable secret 5 $1$h9lx$ZeMfms0rmjHvLCVem/SqV.
enable password 07502628LLZep
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa login success-track-conf-time 1
aaa session-id common
clock timezone CST 8 0
login on-success log
subscriber templating
vpdn enable
license udi pid ISR4321/K9 sn FDO225000UH
license accept end user agreement
license boot level appxk9
no license smart enable
diagnostic bootup level minimal
username cisco privilege 15 password 0 07502628LLZln
username webui privilege 15 password 0 cisco
username admin privilege 15 password 0 123libAdmin
redundancy
mode none
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
interface GigabitEthernet0/0/0
ip address 192.168.108.1 255.255.255.0
ip nat inside
ip access-group 195 in
negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/1.900
encapsulation dot1Q 900
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/0/1.1000
encapsulation dot1Q 1000
ip address 192.168.1.254 255.255.255.0
ip nat outside
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Dialer1
ip address negotiated
ip nat outside
ip access-group 188 out
encapsulation ppp
ip tcp adjust-mss 1400
shutdown
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username 059406012606 password 0 139713
ppp ipcp route default
ip virtual-reassembly
router rip
version 1
network 192.168.0.0
no auto-summary
ip forward-protocol nd
ip ftp source-interface GigabitEthernet0/0/0
ip http server
ip http authentication aaa
ip http secure-server
ip tftp source-interface GigabitEthernet0/0/0
ip dns server
ip nat inside source route-map v1000-1 interface GigabitEthernet0/0/1.1000 overload
ip nat inside source route-map v1000-2 interface Dialer1 overload
ip nat inside source route-map v900-1 interface GigabitEthernet0/0/1.1000 overload
ip nat inside source route-map v900-2 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 192.168.1.1 200
ip route 192.168.0.0 255.255.0.0 GigabitEthernet0/0/0
ip route 192.168.109.0 255.255.255.0 192.168.108.108
ip route 192.168.128.0 255.255.255.0 192.168.108.135
ip route 192.168.128.0 255.255.255.0 GigabitEthernet0/0/0
ip access-list standard EPC
permit any
ip access-list extended lan1
permit ip 192.168.108.0 0.0.0.255 any
ip access-list extended lan2
ip sla 1
icmp-echo 114.114.114.114 source-interface Dialer1
frequency 10
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 114.114.115.115 source-interface Dialer1
frequency 10
ip sla schedule 2 life forever start-time now
ip access-list extended 100
permit icmp 192.168.108.0 0.0.0.255 any
permit tcp 192.168.108.0 0.0.0.255 any
permit udp 192.168.108.0 0.0.0.255 any
ip access-list extended 101
ip access-list extended 102
dialer-list 1 protocol ip permit
arp 192.168.108.1 0029.c2d0.be20 ARPA
arp 192.168.108.254 d478.9bce.0a2b ARPA
route-map yd-1 permit 10
match ip address 101
match interface GigabitEthernet0/0/1.1000
route-map lt-1 permit 10
match ip address 102
route-map lt permit 10
match ip address 102 101
match interface Dialer1
route-map yd permit 10
match ip address 101 102
route-map v900-2 permit 10
match ip address lan1
route-map v900-1 permit 10
route-map v1000-2 permit 10
match ip address lan2
route-map v1000-1 permit 10
control-plane
line con 0
password 07502628LLZln
logging synchronous
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0
password 07502628LLZvt
length 0
transport input ssh
line vty 1 4
password 07502628LLZtm
ntp master
ntp server 0.us.pool.ntp.org
ntp server 1.us.pool.ntp.org
ntp server 2.us.pool.ntp.org
time-range NormalRange
periodic daily 22:00 to 23:59
periodic daily 0:00 to 10:00
time-range timeRangeDeepNight
periodic daily 0:00 to 3:00
time-range timeRangeMidRest
periodic daily 20:30 to 21:05
time-range timeRangeTotalBanChengPad
periodic daily 0:00 to 19:45
periodic daily 21:45 to 23:59
time-range totalRange
periodic daily 0:00 to 23:59
end
06-21-2020 09:03 AM
there is a lot of redundant stuff in your configuration, which I removed. Make sure your config looks like the one below, and test again:
version 16.9
hostname ciscoRT
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
vpdn enable
redundancy
mode none
ip nat inside
negotiation auto
no ip address
negotiation auto
ip nat outside
no ip address
shutdown
negotiation auto
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer persistent
dialer-group 1
no cdp enable
router rip
version 1
network 192.168.0.0
no auto-summary
ip http server
ip dns server
iip route 192.168.109.0 255.255.255.0 192.168.108.108
ip sla 1
frequency 10
control-plane
line con 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0
length 0
transport input ssh
line vty 1 4
ntp master
end
06-21-2020 04:39 PM
hi,thank you
you remove this " ip nat inside source route-map v1000-1 interface GigabitEthernet0/0/1.1000 overload
ip nat inside source route-map v1000-2 interface Dialer1 overload"
i configed this ,but the situation remains unchanged.
06-21-2020 11:07 PM
post the current full running configuration again with the changes you have made...
