ISR4431 in Controller Mode?
jmcgrady1
Ive just booted a new ISR4431 router. Its running IOS 17.5.  It tells me it is in "Controller Mode". How do i make it go to plain ordinary router mode?
16 Replies 16
Kanan Huseynli
controller mode is relevant when you have SD-WAN and you manage routers via controllers (especially, vmanage - sdwan manager).
controller-mode disable
This simple command makes router be autonomous mode and you have regular IOS XE router.
https://www.cisco.com/c/en/us/td/docs/routers/cloud_edge/c8300/software_config/cat8300swcfg-xe-17-book/isr9000swcfg-xe-16-12-book_chapter_01.pdf
HTH,
ibarrazola
To sho what mode your device is in, run the command:
#sho ver | i mode
To exit Controller-Managed Mode and go into Autonomous Mode:
#controller-mode disable
To enter Controller-Managed Mode from Autonomous Mode:
#controller-mode enable
