ISR4451 Nim problem
Hacen.bani
hello,
i have a router ISR 4451 i insered on it a NIM Modules
the module is insereded and detected from the router but the lamp not green and under show inventory i don't see the min serial number also in show platform i see the status of this slot "rebooting"
anybody have a solution please
thanks
15 Replies 15
Leo Laohoo
Post the complete output to the command "sh version". What NIM are you using?
hi,
thanks for reply
attached the show version cammand
thanks
What kind of NIM are you trying to use?
hi,
NIM-2CE1T1-PRI    in slot 0/2
regards
Are you using the NIM-2CE1T1 for data or voice application?
If this is for voice then the license is incorrect. For voice application it is required to have "UC Technology Package".
hi,
is the first utilisation for this isr and the Nim
the router don't have any configuration now
in this moment i need to show the nim functionnely in sh inventory that is all
i have four other isr 4451 with this modules and is work fine with same software version and license
thanks
Ok, so the NIM is used for Data traffic.
Try to put configuration (and enable the ports) and additional LED should light up.
but when i insered the nim i don't show the ports in sh ip int brief
Console into the router and reboot the router.
Post the entire boot-up process.
attached the  boot-up process
error massage
*Jun 26 15:47:12.570: %IOSXE-4-PLATFORM:kernel: ngio_drv: no valid intf found
*Jun 26 15:51:44.683: %SPA_OIR-3-SW_INIT_TIMEOUT: subslot 0/2: SPA initialization not completed
-Traceback= 1#979fbafb2ff8cd30741886a0f5eb9f29 :55C5CB3E6000+7BF6E23 :55C5CB3E6000+7BC5211 :55C5CB3E6000+55DC1EB :55C5CB3E6000+7BC265F :55C5CB3E6000+7BF4CC8 :55C5CB3E6000+6D092C8
*Jun 26 15:51:49.683: %SPA_OIR-3-RECOVERY_RELOAD: subslot 0/2: Attempting recovery by reloading SPA
*Jun 26 15:51:49.683: %SPA_OIR-6-OFFLINECARD: SPA (NIM-2CE1T1-PRI) offline in subslot 0/2
*Jun 26 15:51:49.686: %IOSXE-4-PLATFORM:kernel: ngio_drv: no valid intf found<6>i2c i2c-6: delete_device: Deleting device pca9557 at 0x1c
CSCus36896
thank you
i can solve the problem by upgrade software ??
version 16.03.6 is recommended by cisco
