ISR4451-X WAAS EZconfig setup fail
David Tian
Dear all experts,
when I try to deploy the WAAS services on ISR4451-x router via EZconfig, has below fail log
Choose one of the letter from 'a-d' to edit, 'v' to view config script, 's' to apply config [s]:
The configuration will be applied and the status of the WAAS service will be displayed after deployment
Installing bootflash:/ISR-WAAS-5.5.5.16.ova
installing!!!!
installation failure decision to exit
May 27 06:00:49.494: %VMAN-3-INVALID_PACKAGE:vman: Virtual Service[AUTOWAAS]::Invalid package::Failed to verify virtual service package-def file::Failed to unpack the OVA; Out of None on /vol/harddisk/virtual-instance/AUTOWAAS (19134MB avail, 0MB quota remaining)
If someone know the reason for it ?
Br,
David
5 Replies 5
mbehrle
I am getting the same error even when not going through the EZConfig, seems to be little to no documentation on this
We resolve the error by rebooting the ISR after installing the SSD, once that was complete the harddisk: showed up under "show virtual-service" and we were able to install;
Virtual Service Global State and Virtualization Limits:
Infrastructure version : 1.6
Total virtual services installed : 1
Total virtual services activated : 1
Machine types supported : KVM, LXC
Machine types disabled : none
Maximum VCPUs per virtual service : 6
Resource virtualization limits:
Name Quota Committed Available
system CPU (%) 75 75 0
memory (MB) 10240 8192 2048
bootflash (MB) 1000 0 1000
harddisk (MB) 20000 0 18194  <---  This was not present from this output prior to the reboot
volume-group (MB) 381536 360896 160
Hi Mbehrle, That is right, the issue is resolved after re-deploy the harddisk by below :
request platform hardware filesystem harddisk: destroy
hw-module subslot 0/1 reload
Check if the harddisk is there:
dir harddisk:
and reload it.
Just reloading the harddisk itself did not resolve the problem for us, it required a full reboot of the ISR.
I have same issue with a 4331. I bougth at 200GB SSD Drive but it appears to be only 20GB ..is this correct? It's the same output as above.
xxxxx-r01#sh virtual-service
Infrastructure version : 1.7
Total virtual services installed : 0
Total virtual services activated : 0
system CPU (%) 75 0 75
memory (MB) 10240 0 10240
harddisk (MB) 20000 0 19134
volume-group (MB) 190768 0 170288
xxx-r01#
I can't enable the WAAS service either:
Installing bootflash:/ISR-WAAS-6.2.3e.45.ova
installing!!!!!!!!!!!!!!!!!!!!!!!
