Issue about Cisco 3825 with bridged DSL modem
hxmengmetro
Hi All,
We have cisco 3825 router with 1 FE card which is connected to one bridged DSL router. DSL router only does bridge function. The other giga interface is connected to the corporate network. So I want to some traffic goes through the DSL connection. So I configured the dialer, dialer list and which traffic should go through DSL in the routing. But it seems the dialer interface can't be up. We have static IP with AT&T. Either I configure static IP with dialer interface or leave it negotiate, it won't be up. Here is my related configuration:
vpdn enable
vpdn-group 1
request-dialin
  protocol l2tp
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap
ppp pap sent-username xxxxx password 7 xxxxx
no cdp enable
access-list 1 permit 10.x.x.0 0.0.0.255
dialer-list 1 protocol ip permit
ip nat inside source list 1 interface Dialer1 overload
Any help is greatly appreciated.
Lou
Todd Pula
Level 7
Level 7
I am assuming that this is a PPPoE configuration in which case you will need to associate the dialer pool with the interface facing the modem.  Below is a sample config for your reference.
interface GigabitEthernet0/1
description ** Outside Interface **
no ip address
ip virtual-reassembly
duplex auto
speed auto
media-type rj45
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname testuser@att.net
ppp chap password 7 1a1a1a1a1a1a1a1a1a1a
ppp pap sent-username testuser@att.net password 7 1a1a1a1a1a1a1a1a1a1a
paolo bevilacqua
You do not need the vpdn commands.
But you do need pppoe enable and pppoe-client commands under fastethernet interface.
Todd Pula
Level 7
Level 7
no ip address
duplex auto
speed auto
media-type rj45
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
Thanks a lot. After I delete VPDN config, it still doesn't work. Called AT&T and found some issue at their side. Finally it's working now. Thank you for the help!
Lou
