Issue in Router 2911
itp.farouk
 Hi all, i have Router Cisco 2911 with 4 wic ADSL and 3 GIGAethernet. the issue is i configure 2 wic ADSL and its up, but i can't assign each dialer to specify Ethernet interface. all traffic routed to 1st dialer and don't want to routing to dialer2.
mainly i want to use this router to static routing 4 local sub-net for internet every subnet run through dialer without load balance or fail over.
my configuration as below:
version 15.5
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
memory-size iomem 25
clock timezone UTC 2 0
no ip domain lookup
ip cef
no ipv6 cef
redundancy
controller VDSL 0/0/0
controller VDSL 0/1/0
controller VDSL 0/2/0
controller VDSL 0/3/0
interface Embedded-Service-Engine0/0
no ip address
ip broadcast-address 0.0.0.0
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 8
ip address 192.168.8.2 255.255.255.0
ip nat inside
ip nat enable
ip virtual-reassembly in
interface GigabitEthernet0/0.2
encapsulation dot1Q 121
ip address 192.168.121.2 255.255.255.0
ip nat inside
ip nat enable
ip tcp adjust-mss 1412
interface GigabitEthernet0/1
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
pvc 0/35
pppoe-client dial-pool-number 2
interface Ethernet0/0/0
no ip address
interface ATM0/1/0
no ip address
interface ATM0/1/0.1 point-to-point
pvc 0/35
pppoe-client dial-pool-number 3
interface Ethernet0/1/0
no ip address
interface ATM0/2/0
no ip address
interface ATM0/2/0.1 point-to-point
pvc 0/35
interface Ethernet0/2/0
no ip address
interface ATM0/3/0
no ip address
interface Ethernet0/3/0
no ip address
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
ip policy route-map dialer1
dialer pool 2
dialer-group 2
ppp authentication pap callin
ppp pap sent-username xxx@xxxx.com password 0 xxxx
ppp ipcp dns request
interface Dialer2
ip mtu 1452
ip nat outside
encapsulation ppp
ip policy route-map dialer2
dialer pool 3
dialer-group 3
ppp chap hostname xxx@xxxx.com
ppp chap password 0 xxx
ppp pap sent-username username xxx@xxxx.com password 0 xxxx
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static 192.168.8.2 interface Dialer1
ip nat inside source static 192.168.121.2 interface Dialer2
ip nat inside source list 190 interface Dialer2 overload
ip route profile
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0.1
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0.2
ip ssh time-out 60
ip ssh source-interface GigabitEthernet0/1
ip access-list extended line1
dialer-list 2 protocol ip permit
dialer-list 3 protocol ip permit
route-map dialer2 permit 10
match ip address 160
set ip next-hop dynamic dhcp
route-map dialer1 permit 10
match ip address 150
access-list 1 permit any
access-list 150 permit ip 192.168.8.0 0.0.0.255 any
access-list 160 permit ip 192.168.121.0 0.0.0.255 any
access-list 190 permit ip any any
control-plane host
control-plane
vstack
end
5 Replies 5
Seb Rupik
Hi there,
Please can you provide us with the output from:
sh route-map
sh version
Also whilst we are here, you may want to disable the smart install feature on your router;
no vstack
https://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20120328-smartinstall
...unless you are using it, in which case secure it with an ACL.
cheers,
Seb.
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
System image file is "flash0:c2900-universalk9_npe-mz.SPA.155-3.M6a.bin"
router#sh route-map
route-map dialer2, permit, sequence 10
Match clauses:
ip address (access-lists): 160
Set clauses:
ip next-hop dynamic dhcp - current value is UNKNOWN
Policy routing matches: 0 packets, 0 bytes
route-map dialer1, permit, sequence 10
Match clauses:
ip address (access-lists): 150
Set clauses:
Policy routing matches: 11 packets, 728 bytes
OK, there is your problem:
..neither route-map knows which gateway to use via DHCP.
The configuration guides states:
Spoiler
The set ip next-hop dynamic dhcp command supports only a single DHCP interface. If multiple interfaces have DHCP configured, the gateway that was most recently learned among all interfaces running DHCP will be used by the route map.
https://www.cisco.com/en/US/products/ps6922/products_command_reference_chapter09186a00806c0a3f.html#wp1013323
...but neither route-map has a gateway.
Is it possible to statically assign the ISP IP address used on dialer2 ? Check the arp cache (sh ip arp) to determine this.
cheers,
Seb.
it's already configured ip next-hop dynamic dhcp
but i don't know you it's appear Unknown
  Match clauses:
  Set clauses:
  Match clauses:
  Set clauses:
hossien#sh ip int br dialer 1
Interface                  IP-Address      OK? Method Status                Protocol
Dialer1                    41.244.1.162   YES IPCP   up                    up
What is the output of sh int dialer 2 ?
There should be a line starting with 'Internet address x.x.x.x'
Use the IP address specified in your route-map:
  set ip next-hop x.x.x.x
cheers,
Seb.
