Issue with a 1941 router
hector.estevez
We have a very weird issue:
We own several public IP addresses. When we have a service that needs internet public access, we just create a NAT rule that points from 1 of our public IP addresses to the server in our LAN where the service resides. This nat rules especifies the port where it should be accepting traffic.
The problem comes when we discovered that 1 of our public IPs is routing http traffic to our printer´s web server. I´ve double checked and I don´t find any NAT rule that would allow this traffic to reach our printer from this address. So, why does this happens?
Any suggestions?
TY
9 Replies 9
John Blakley
Can you post your nat config?
HTH, John *** Please rate all useful posts ***
Hello, thanks for answering. Here are my nat rules:
ip nat pool desarrollos *.*.*.* *.*.*.*.* prefix-length 29
ip nat inside source list 7 pool desarrollos overload
ip nat inside source static tcp 172.16.16.125 8000 *.*.*.* 8000 extendable
ip nat inside source static tcp 172.16.16.125 8003 *.*.*.* 8003 extendable
ip nat inside source static tcp 172.16.16.125 8004 *.*.*.* 8004 extendable
ip nat inside source static tcp 172.16.16.125 8006 *.*.*.* 8006 extendable
ip nat inside source static tcp 172.16.16.125 8007 *.*.*.* 8007 extendable
ip nat inside source static tcp 172.16.16.125 8080 *.*.*.* 8080 extendable
ip nat inside source static tcp 172.16.16.127 443 *.*.*.* 443 extendable
ip nat inside source static tcp 172.16.16.127 8080 *.*.*.* 8080 extendable
ip nat inside source static tcp 172.16.16.127 8081 *.*.*.* 8081 extendable
ip nat inside source static tcp 172.16.16.167 8084 *.*.*.* 8084 extendable
ip nat inside source static tcp 172.16.16.127 8083 *.*.*.* 8083 extendable
ip nat inside source static tcp 172.16.16.127 8586 *.*.*.* 8586 extendable
ip nat inside source static tcp 172.16.16.122 80 *.*.*.* 80 extendable
ip nat inside source static tcp 172.16.16.122 443 *.*.*.* 443 extendable
ip nat inside source static udp 172.16.16.124 1194 *.*.*.* 1194 extendable
Note that I only have 1 port 80 rule, and it´s not pointing to my printer.
Do you need any more info?
Thanks again.
That's interesting. Do you have a printer mapped with a static nat translation? Can you do "show ip nat trans | inc " and post the results?
Sure:
show ip nat trans | inc 172.16.16.34
tcp A.A.A.A:80 172.16.16.34:80    190.6.62.86:40230  190.6.62.86:40230
tcp A.A.A.A:80 172.16.16.34:80    190.6.62.86:40234  190.6.62.86:40234
---  A.A.A.A    172.16.16.34       ---                ---
Mmmm What does this means? it clearly shows that is nating the A.A.A.A address to my printer (172.16.16.34), but why? :-/
Note: A.A.A.A is the public address that points to my printer web portal as I said in the first post.
By the way, I don´t know what that 190.6.62.86 address is...
Thanks again.
Address:  190.6.62.86
Is your printer web portal mapped to one of the outgoing IPs in the pool by chance?
Not that I´m aware of.... how can I check that?
Do a "sh run | inc ip nat pool" If your public address that your printer is natting to is in that pool, I'm going to assume that someone was able to connect to it before the translation expired.
Do you have an acl on your outside interface to allow only traffic into your network to the IPs that you have configured for static nat? You should....
Well I did a "sh run | inc ip nat pool" and yes, the Ip address is included on this pool. What does it means?
My first thought is that your web server went out to the web and had the address mapped. Once that happened, someone connected to the mapped ip address and it never timed out. Can you answer the other question if you have an acl on your outside interface?
