Issue with GLBP
Hi Guys,
I'm currently in the middle of setting up a leased line connection from Site A to Site B using 2 pairs of leased line circuit with GLBP for balancing purposes. At site B, i already have 2 servers with IP 172.20.60.11 and 172.20.60.12. The issue that i'm having rigth now is that from both routers in Site A, i could not ping to this 2 servers but i'm able to ping the VIP of the LAN at site B. From the routers in site B, I have no issue to ping to the said servers. Attached is a diagram to help explaiin further regarding my Architecture. Below is the GLBP command at site B routers.
Site B Router 1 Config
track 1 interface Serial0/0/0 line-protocol
interface GigabitEthernet0/0.1
description ** Site B Svr Frm  **
encapsulation dot1Q 60
ip address 172.20.60.2 255.255.255.0
ip load-sharing per-packet
glbp 10 ip 172.20.60.1
glbp 10 priority 110
glbp 10 preempt delay minimum 60
glbp 10 weighting 110 lower 95 upper 100
glbp 10 authentication text yyy
glbp 10 weighting track 1 decrement 50
ip route 172.25.63.75 255.255.255.255 10.35.0.2
R1#sh glbp
GigabitEthernet0/0.1 - Group 10
  State is Active
    85 state changes, last state change 00:43:59
  Virtual IP address is 172.20.60.1
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 1.888 secs
  Redirect time 600 sec, forwarder timeout 14400 sec
  Authentication text, string "bursa@csc"
  Preemption enabled, min delay 60 sec
  Active is local
  Standby is 172.20.60.3, priority 100 (expires in 8.160 sec)
  Priority 110 (configured)
  Weighting 110 (configured 110), thresholds: lower 95, upper 100
    Track object 1 state Up decrement 50
  Load balancing: round-robin
  Group members:
    2894.0f5a.9e00 (172.20.60.3)
    649e.f3f4.aa80 (172.20.60.2) local
  There are 2 forwarders (1 active)
  Forwarder 1
    State is Active
      37 state changes, last state change 00:44:29
    MAC address is 0007.b400.0a01 (default)
    Owner ID is 649e.f3f4.aa80
  Redirection enabled
    Preemption enabled, min delay 30 sec
    Active is local, weighting 110
    Client selection count: 1411
  Forwarder 2
    State is Listen
      52 state changes, last state change 00:17:00
    MAC address is 0007.b400.0a02 (learnt)
    Owner ID is 2894.0f5a.9e00
    Redirection enabled, 598.176 sec remaining (maximum 600 sec)
    Time to live: 14398.176 sec (maximum 14400 sec)
    Active is 172.20.60.3 (primary), weighting 110 (expires in 10.048 sec)
    Client selection count: 5
Site B Router 2 Config
description ** Svr Frm **
ip address 172.20.60.3 255.255.255.0
ip route 172.25.63.75 255.255.255.255 10.45.0.2
R2#sh glbp
  State is Standby
    34 state changes, last state change 00:19:34
    Next hello sent in 1.376 secs
  Active is 172.20.60.2, priority 110 (expires in 9.184 sec)
  Standby is local
  Priority 100 (default)
  Group members:
    2894.0f5a.9e00 (172.20.60.3) local
  Forwarder 1
    State is Listen
      54 state changes, last state change 00:45:30
    MAC address is 0007.b400.0a01 (learnt)
Time to live: 14398.560 sec (maximum 14400 sec)
    Active is 172.20.60.2 (primary), weighting 110 (expires in 10.208 sec)
    Client selection count: 1467
  Forwarder 2
    State is Active
      33 state changes, last state change 00:18:01
    MAC address is 0007.b400.0a02 (default)
    Client selection count: 1466
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Try an extended ping from one of the site B routers to a site B server sourcing from a WAN link interface.  If that also doesn't work, try check the site B server has the correct site B virtual gateway IP.
Joseph W. Doherty
Disclaimer
Posting
patrick.preuss
Hi Joseph
how are you routes set ?
Please give us a traceroute for the failing.
Cheers
Patrick
Hi Guys,
Thanks for the feedback. After talking to my support team in charge of that particular server, i was inform that the server has 2 NIC with 2 Default gateway. after asking the server team to add in a static route at the server itself, the problem has been solved. The clue was when i did an extended ping from Router B's Wan interface, i did not receive any reply. Thanks again Joseph and Patrick.
