How to automatically remove invalid injected route?
sydflyer2011
Hi Guys,
I have a question in regards to route redistriubtion. For example:
Router A has enabled BGP and EIGRP, and its EIGRP neighbour is Router B. Now Router A redistriubte BGP learned route to EIGRP process, Say, one of the BGP learned route is called Redistribute_BGP. Then, Router B learned the Redistribute_BGP from EIGRP and put it into its routing protocol.
OK, now, Router A's BGP session is broken and lost its BGP learned routes. However, Router B still has the Redistribute_BGP in its routing table. My question is how to get this Redistribute_BGP route removed from Router B's routing table after Router A lose its BGP routes.  Is there any "trigger"? or workarounds? Thanks.
Alex
paolo bevilacqua
is that a theoretical question? That is not normal. The route should be withdrawn at the time BGP session is down.
Hi Paolo,
Thanks for your answer. I think you are right. Eventually I've seen the route is withdrawn but just way too late to see it happening on Router B as soon as BGP session is down.
You're welcome. Please remember to rate useful posts clicking on the stars below.
Like it should be removed route from eigrp routing table .........wait till the eigrp flush time .
afterthat it will definatly remove the route .
i have one question ?
R u creating the this topology in GNS ? if yes then might be changes becasue it behave some time very weird .
do u r getting all the prefix from ISP or default route .
if only default route then check in your config is there any command u config like
default information originate
Ritesh
