Issue with netbios
nawafaziz78284
Kindly can help me with that issue , actually i'm trying to block the netbios on cisco 4300 router.
i already applied this few command :
ip access-list extended NETBIOS
deny tcp any any eq 135
deny udp any any eq 135
deny tcp any any range 137 139
deny udp any any range 137 139
deny tcp any any eq 445
deny udp any any eq 445
permit ip any any
but the netbios still enable .
please i need your support .
thanks
5 Replies 5
Mark Elsen
 - Perhaps this thread may enlighten you further :
          https://community.cisco.com/t5/switching/how-to-block-netbios/td-p/1429992
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
i already did .. but still not blocked  .. i hope some body help me to fix this issue .
Joseph W. Doherty
How are you applying your ACL?
Reason I ask, your ACL will block source to destination only. (It also assumes only "known" ports being used.)
Thanks for your support .. And do you know how can i block ( disable ) the netbios .. What is miss in the top command .
Sorry, I don't understand this post.
