How to Block Netbios
PRASAD BAIT
I have cisco 1800 series router and i want to block Netbios on that.
Jayakrishna Mada
Hi Prasad,
Do you have ip helper addess configured on the switch if yes then configure
no ip forward-protocol udp 137
no ip forward-protocol udp 138
no ip forward-protocol udp 139
if not you can configure and apply this access-list:
access-list 110 deny   tcp any any range 137 139
access-list 110 deny   udp any any eq netbios-ss
access-list 110 deny   udp any any eq netbios-dgm
Hope this helps.
JayaKrishna
Hi Jayakrishna,
thanks for your support.
But plz tell me that is there any need to configure the ip helper address or not???
Prasad,
Here is the answer to your question:
http://www.ciscotaccc.com/kaidara-advisor/iprout/showcase?case=K83798834
There is no need to configure IP helper address if you dont have one. You can still use the access-list to block NETBIOS.
JayaKrishna
