09-22-2020 02:45 PM
Me again with more CCNP studying. So in gns 3 I have the following topology:
R1 is running a multi vrf/multi ospf process. I'm trying to simulate something like what an ISP would potentially do. So the ospf adjacency between R1 and R3 comes up fine...and the other 2 do not. I have no clue what I'm doing wrong. Probably being stupid and missing something simple but I can't figure it out. Here's the configs:
R1:
R1#sh run int g1/0 Building configuration... Current configuration : 183 bytes ! interface GigabitEthernet1/0 description TO-R2 ip vrf forwarding R2 ip address 10.255.5.1 255.255.255.0 ip ospf dead-interval 3 ip ospf hello-interval 1 negotiation auto end R1#sh run int g2/0 Building configuration... Current configuration : 183 bytes ! interface GigabitEthernet2/0 description TO-R4 ip vrf forwarding R4 ip address 10.255.6.1 255.255.255.0 ip ospf dead-interval 3 ip ospf hello-interval 1 negotiation auto end R1#sh run int g3/0 Building configuration... Current configuration : 183 bytes ! interface GigabitEthernet3/0 description TO-R3 ip vrf forwarding R3 ip address 10.255.7.1 255.255.255.0 ip ospf dead-interval 3 ip ospf hello-interval 1 negotiation auto end R1#sh run | s ospf ip ospf dead-interval 3 ip ospf hello-interval 1 ip ospf dead-interval 3 ip ospf hello-interval 1 ip ospf dead-interval 3 ip ospf hello-interval 1 router ospf 1 vrf R2 router-id 5.1.1.1 network 10.255.5.1 0.0.0.0 area 0 router ospf 2 vrf R4 router-id 5.1.1.2 network 10.255.6.1 0.0.0.0 area 0 router ospf 3 vrf R3 router-id 5.1.1.3 network 10.255.7.1 0.0.0.0 area 0
R2:
Interface IP-Address OK? Method Status Protocol FastEthernet0/0 unassigned YES unset administratively down down GigabitEthernet1/0 10.255.5.2 YES manual up up GigabitEthernet2/0 192.168.1.1 YES manual up up GigabitEthernet3/0 unassigned YES unset administratively down down GigabitEthernet4/0 unassigned YES unset administratively down down GigabitEthernet5/0 unassigned YES unset administratively down down GigabitEthernet6/0 unassigned YES unset administratively down down Loopback1 172.65.1.1 YES manual up up Loopback2 172.65.2.1 YES manual up up Loopback3 172.65.3.1 YES manual up up R2# R2#sh run int g1/0 Building configuration... Current configuration : 161 bytes ! interface GigabitEthernet1/0 description TO-R1 ip address 10.255.5.2 255.255.255.0 ip ospf dead-interval 2 ip ospf hello-interval 1 negotiation auto end R2# R2#sh run | s ospf ip ospf dead-interval 2 ip ospf hello-interval 1 router ospf 1 router-id 2.2.2.2 network 10.255.5.2 0.0.0.0 area 0 network 172.65.1.1 0.0.0.0 area 0 network 172.65.2.1 0.0.0.0 area 0 network 172.65.3.1 0.0.0.0 area 0
R4:
R4#sh ip int br Interface IP-Address OK? Method Status Protocol FastEthernet0/0 unassigned YES unset administratively down down GigabitEthernet1/0 10.255.6.2 YES manual up up GigabitEthernet2/0 192.168.2.1 YES manual up up GigabitEthernet3/0 unassigned YES unset administratively down down GigabitEthernet4/0 unassigned YES unset administratively down down GigabitEthernet5/0 unassigned YES unset administratively down down GigabitEthernet6/0 unassigned YES unset administratively down down Loopback1 172.65.4.1 YES manual up up Loopback2 172.65.5.1 YES manual up up Loopback3 172.65.6.1 YES manual up up R4# R4#sh run int g1/0 Building configuration... Current configuration : 142 bytes ! interface GigabitEthernet1/0 ip address 10.255.6.2 255.255.255.0 ip ospf dead-interval 3 ip ospf hello-interval 1 negotiation auto end R4# R4#sh run | s ospf ip ospf dead-interval 3 ip ospf hello-interval 1 router ospf 1 router-id 4.4.4.4 network 10.255.6.1 0.0.0.0 area 0 network 172.65.4.1 0.0.0.0 area 0 network 172.65.5.1 0.0.0.0 area 0 network 172.65.6.1 0.0.0.0 area 0
R3:
R3#sh ip int br Interface IP-Address OK? Method Status Protocol FastEthernet0/0 unassigned YES unset administratively down down GigabitEthernet1/0 10.255.7.2 YES manual up up GigabitEthernet2/0 192.168.3.1 YES manual up up GigabitEthernet3/0 unassigned YES unset administratively down down GigabitEthernet4/0 unassigned YES unset administratively down down GigabitEthernet5/0 unassigned YES unset administratively down down GigabitEthernet6/0 unassigned YES unset administratively down down Loopback1 172.65.7.1 YES manual up up Loopback2 172.65.8.1 YES manual up up Loopback3 172.65.9.1 YES manual up up R3# R3#sh run int g1/0 Building configuration... Current configuration : 142 bytes ! interface GigabitEthernet1/0 ip address 10.255.7.2 255.255.255.0 ip ospf dead-interval 3 ip ospf hello-interval 1 negotiation auto end R3# R3#sh run | s ospf ip ospf dead-interval 3 ip ospf hello-interval 1 router ospf 1 router-id 3.3.3.3 network 10.255.7.2 0.0.0.0 area 0 network 172.65.7.1 0.0.0.0 area 0 network 172.65.8.1 0.0.0.0 area 0 network 172.65.9.1 0.0.0.0 area 0
So again, the R3 stuff works fine. If I go on R1 and do
sh ip ro vrf R3
I get
R1#sh ip ro vrf R3
Routing Table: R3
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.255.7.0/24 is directly connected, GigabitEthernet3/0
L 10.255.7.1/32 is directly connected, GigabitEthernet3/0
172.65.0.0/32 is subnetted, 3 subnets
O 172.65.7.1 [110/2] via 10.255.7.2, 00:05:42, GigabitEthernet3/0
O 172.65.8.1 [110/2] via 10.255.7.2, 00:05:42, GigabitEthernet3/0
O 172.65.9.1 [110/2] via 10.255.7.2, 00:05:42, GigabitEthernet3/0But the vrf/ospf between R2 and R4 doesn't work. debug ip ospf adjacency shows nothing. debug ip ospf packets shows
*Sep 22 17:41:29.082: OSPF-1 PAK : rcv. v:2 t:1 l:44 rid:2.2.2.2 aid:0.0.0.0 chk:D8C8 aut:0 auk: from GigabitEthernet1/0 *Sep 22 17:41:29.410: OSPF-3 PAK : rcv. v:2 t:1 l:48 rid:3.3.3.3 aid:0.0.0.0 chk:BCBD aut:0 auk: from GigabitEthernet3/0 R1# *Sep 22 17:41:30.082: OSPF-1 PAK : rcv. v:2 t:1 l:44 rid:2.2.2.2 aid:0.0.0.0 chk:D8C8 aut:0 auk: from GigabitEthernet1/0 *Sep 22 17:41:30.410: OSPF-3 PAK : rcv. v:2 t:1 l:48 rid:3.3.3.3 aid:0.0.0.0 chk:BCBD aut:0 auk: from GigabitEthernet3/0 *Sep 22 17:41:31.026: OSPF-1 PAK : rcv. v:2 t:1 l:44 rid:2.2.2.2 aid:0.0.0.0 chk:D8C8 aut:0 auk: from GigabitEthernet1/0 R1# *Sep 22 17:41:31.338: OSPF-3 PAK : rcv. v:2 t:1 l:48 rid:3.3.3.3 aid:0.0.0.0 chk:BCBD aut:0 auk: from GigabitEthernet3/0 *Sep 22 17:41:31.930: OSPF-1 PAK : rcv. v:2 t:1 l:44 rid:2.2.2.2 aid:0.0.0.0 chk:D8C8 aut:0 auk: from GigabitEthernet1/0 *Sep 22 17:41:32.334: OSPF-3 PAK : rcv. v:2 t:1 l:48 rid:3.3.3.3 aid:0.0.0.0 chk:BCBD aut:0 auk: from GigabitEthernet3/0 R1# *Sep 22 17:41:32.894: OSPF-1 PAK : rcv. v:2 t:1 l:44 rid:2.2.2.2 aid:0.0.0.0 chk:D8C8 aut:0 auk: from GigabitEthernet1/0 *Sep 22 17:41:33.338: OSPF-3 PAK : rcv. v:2 t:1 l:48 rid:3.3.3.3 aid:0.0.0.0 chk:BCBD aut:0 auk: from GigabitEthernet3/0 *Sep 22 17:41:33.818: OSPF-1 PAK : rcv. v:2 t:1 l:44 rid:2.2.2.2 aid:0.0.0.0 chk:D8C8 aut:0 auk: from GigabitEthernet1/0
and that just repeats.
I've already removed all the ospf instances on R1 and remade them, and I took all the cables out of GNS3 and re-did those as well. Not sure what I'm doing wrong.
Solved! Go to Solution.
09-22-2020 02:49 PM
And my routing advertisement on R4 had 10.255.6.1 instead of 10.255.6.2
I guess I just needed to post it to see it all laid out haha. Thanks for all who took the time to read anyway.
09-22-2020 02:47 PM
Ok so as soon as I posted I realized I had the dead interval wrong on the link to R2. Fixed that and it came up. Still no luck with R4 though.
09-22-2020 02:49 PM
