Issue with PBR and VPN access
hello, I'm trying to configure the network of my company to provide performance and VPN incoming connections. The network is made of: - 10Gb core-switch - 1Gb top of rack switches with a 10Gb to core-switch connection - multiple vlans - Cisco ASA 5515-X servers <--------> 10Gb CoreSwitch <------> TopOfRack switch <-----> Cisco ASA <---------> Internet <----------> VPN Users 172.17.10.240 172.17.10.254 So far, I tested the following: TEST 1: ======== Set gateway to IP address of the core switch. The performance are present as all inter vlans is managed by the core switch. All my vlans have a rule "allow all" or "deny all". I don't have port or IP filtering. I configured "policy based routing" on the core-switch and set the "next-hop" IP adddress to be the Cisco ASA. --> This configuration works very well for outgoing and intervlan traffic. The only issue is that my remote users connecting by VPN cannot connect to local resource. TEST 2: ======== Set gateway to IP address of the Cisco ASA. --> This configuration works very well for outgoing and intervlan traffic. The only issue is that the Cisco ASA is handling all interval traffic with a 1Gb connection, resulting in a bottleneck. I cannot find a viable solution combining performance and VPN connection. I'd appreciate all discussion or suggestion. Thank you in advance, Thierry
can you draw your setup out and post it ? Inter-VLAN routing should happen at the core switch, not the ASA, only Internet traffic should go out to the ASA.
hello Georg,
I entirely agree that intervlan routing shoud happen on the core-switch.
Please find attached my setup.
For outgoing traffic (everything works fine):
- my internal Equipment has an IP 172.17.110.100 with Gateway 172.17.110.240 (core-switch)
- my core-switch has PBR enabled and forward the traffic (using set next-hop) to the ASA (172.17.110.254)
- the ASA forwards the traffic to the Internet
For incoming traffic (using remote VPN):
- my client has an IP assigned by a pool assigned by DHCP from the ASA)
- I can reach my ASA
- The problem is that my remote client cannot reach the internal LAN. The cause must be due to an asymetric route, the internal Equipment having a default Gateway of 172.17.110.240 and my ASA having an IP of 172.17.110.254.
Hope this helps,
Thierry
