Issue with routing protocol multicast packet transmission on SVI
stevesmith741
Originally posted in wrong discussion group (Nexus Developers)
Hi all,
I've run across an issue when trying to enable RIP and OSPF on SVI interfaces on my
nx-osv
instances. Getting this output from
debug l2fwder error
2023 Aug 12 02:04:20.571324 l2fwd: l2fwder_get_mac_lookup_fwd_info(784):l2fwder_get_mac_lookup_fwd_info: Unsupported frame [0100.5e00.0009] etype[2048
2023 Aug 12 02:04:21.020643 l2fwd: l2fwder_get_mac_lookup_fwd_info(784):l2fwder_get_mac_lookup_fwd_info: Unsupported frame [0100.5e00.0005] etype[2048
Not sure if that missing closing square bracket after
2048
is a clue. Probably just cosmetic.
I also observe these drop counters in
show l2fwder statistics
output:
Switching stats:
Unicast 0
Flood 41
Multicast 0
Punt 140
Drop 26204
No issues with RIP or OSPF multicast packet transmission on routed interfaces or sub-interfaces, only with SVIs. No issues with unicast transmission on SVIs. Anyone aware if this is a limitation of
nx-osv
? I can't see any obvious limitations listed that would affect this functionality.
Running version is titanium
-d1-kickstart.7.3.0.D1.1. Running in EVE-NG
Any help greatly appreciated!
Steve
Peter Paluch
Hi Steve,
What you're observing is definitely a bug (
CSCuz98156
sadly not publicly accessible) which was fixed internally for the
l2fwd
component. Unfortunately, the
NX-OSv
project itself is obsolete and to my best knowledge, we did not publicly release any newer versions of the
NX-OSv
(the virtual Nexus 7000 series). These images are deprecated and instead of them,
NX-OS 9000v
should be used.
Sorry for disappointing you - I wish I had better news.
Best regards,
Peter
Peter Paluch
Hi Steve,
CSCuz98156
l2fwd
NX-OSv
NX-OSv
NX-OS 9000v
should be used.
Best regards,
Peter
Thanks for taking the trouble to look into this Peter. I have indeed decided to work with the
9000v
instead of the Titanium image. It seems to come with its own bag of troubles as well (
VPC peer
keepalives not working, LACP not working), but hopefully I'll overcome with enough perserverance!
