Issues blackholing an IP using BGP with community strings
Brandon Baker
I am trying to blackhole an ip with an upstream provider but am having no luck. They say they are not receiving the community string from me. This is what I am entering:
6461:5990 is Zayo blackhole community
conf t
route-map ddos permit 10
set community 6461:5990
ip route X.X.128.88 255.255.255.255 Null0
router bgp (AS NUMBER)
neighbor (zayo ip) send-community
network X.X.128.88 mask 255.255.255.255 route-map ddos
I have also just tried
ip access-list permit 24 X.X.128.88
match ip address 24
neighbor (zayo ip) route-map ddos out
Does anyone see anything wrong with either of these commands?
Hello
can you post the output from this please:
sh ip bgp neighbors | s Neighbor capabilities
res
Paul
Kind Regards
Paul
It may be working now- I am awaiting a response from Zayo:
here is the requested output:
Neighbor capabilities:
    Route refresh: advertised and received(new)
    Four-octets ASN Capability: advertised and received
    Address family IPv4 Unicast: advertised and received
    Graceful Restart Capability: received
      Remote Restart timer is 120 seconds
      Address families advertised by peer:
        IPv4 Unicast (was not preserved
    Enhanced Refresh Capability: advertised
    Multisession Capability:
    Stateful switchover support enabled: NO for session 1
        none
        none
Hello
This is what I was looking for on you bgp peerings   <---  Four-octets ASN Capability: advertised and received
Which mean both sides ogf the peering support that feature however I did notice just the advertised on one of them
res
Paul
Kind Regards
Paul
CSCO12744192
Hello Brandon Baker,
it may be silly question but want to insure , did you have insure also that network is being seeing at the advertisement list to the peer by :
show ip bgp neighbors (zayo ip) advertise
also i don't know if you have entered it but in order to use the community from the syntax XXXX:XXXX and not XXXXXXXX you should enter:
ip bgp-community new-format , that because by default the bgp display this community as 4byte number but when it command entered it display it as 2byte/2byte community that may be the problem.
