Issues Connection Internet to Cisco 2960 Switch
WVerga
Have been studying for my CCNA and got some equipment to help me out (I actually have 2 of each but am only using 1 as I am networking my room as I study)
I can ping the Computer from the router but there is no internet activity
Using my wifi off my Fios Router till I get this working
Connections:
Fios Internet Router <-----> (G0/1) Cisco Router (G0/0) <-----> (G0/1) Cisco Switch <-----> TV/Printer/PS4/PC/Cable Box
Please help
Configs are below for both
replaced passwords with *'s for safety
21 Replies 21
Switch IP INT BR:
MB-SW>en
Password:
MB-SW#sh ip int br
Vlan1 192.168.4.2 YES manual up up
FastEthernet0/1 unassigned YES unset up up
FastEthernet0/2 unassigned YES unset down down
FastEthernet0/3 unassigned YES unset down down
FastEthernet0/4 unassigned YES unset up up
FastEthernet0/5 unassigned YES unset up up
FastEthernet0/6 unassigned YES unset administratively down down
FastEthernet0/7 unassigned YES unset down down
FastEthernet0/8 unassigned YES unset administratively down down
FastEthernet0/9 unassigned YES unset administratively down down
FastEthernet0/10 unassigned YES unset administratively down down
FastEthernet0/11 unassigned YES unset administratively down down
FastEthernet0/12 unassigned YES unset administratively down down
FastEthernet0/13 unassigned YES unset administratively down down
FastEthernet0/14 unassigned YES unset administratively down down
FastEthernet0/15 unassigned YES unset administratively down down
FastEthernet0/16 unassigned YES unset administratively down down
FastEthernet0/17 unassigned YES unset administratively down down
FastEthernet0/18 unassigned YES unset administratively down down
FastEthernet0/19 unassigned YES unset administratively down down
FastEthernet0/20 unassigned YES unset administratively down down
FastEthernet0/21 unassigned YES unset administratively down down
FastEthernet0/22 unassigned YES unset administratively down down
FastEthernet0/23 unassigned YES unset administratively down down
FastEthernet0/24 unassigned YES unset administratively down down
GigabitEthernet0/1 unassigned YES unset up up
GigabitEthernet0/2 unassigned YES unset down down
so the DHCP works now ?
Either way, if you do a traceroute from the PC to 8.8.8.8, where does it stop ? Can you ping 8.8.8.8 from the router ?
DHCP is not working on any of the devices, I can only ping 192.158.4.1
It will not ping to the internet
can you ping 8.8.8.8 from the router ?
no,
Router IP INT BR:
For Administrator Access Only
MBR>en
Password:
MBR#sh ip int br
Embedded-Service-Engine 0/0    172.27.140.2                 YES                  NVRAM                  initializing            down
GigabitEthernet 0/0                      192.168.4.1                   YES                  manual                        up                    up
GigabitEthernet 0/0.2                   192.168.2.1                   YES                  NVRAM                       up                     up
GigabitEthernet 0/0.3                   192.168.3.1                   YES                  NVRAM                       up                     up
GigabitEthernet 0/0.10                 unassigned                     YES                    unset                     deleted              down
GigabitEthernet 0/1                      192.168.1.2                   YES                   manual                       up                     up
Serial 0/0/0                                  unassigned                    YES                   NVRAM                    down                 down
NVI0                                             unassigned                    YES                    unset                         up                      up
Fixed it
Set Router port (G0/1) connected to Fios Router to : IP Address DHCP
Then tweaked the static IP of the PC and Presto
Hello
Based on your original topology - change the following
RTR
interface GigabitEthernet0/0
no ip address 192.168.2.222 255.255.255.0
interface GigabitEthernet0/0.3
encapsulation dot1q 3
description Network VLAN
ip nat inside
ip dhcp pool dpool1
default-router 192.168.1.212
Switch
default interface GigabitEthernet0/1
switchport mode trunk
switchport trunk allowed vlan 3
no shut
Kind Regards
Paul
