Spoke to spoke connectivity
Mayur Aher
In our organization we have hub to spoke connectivity.
But now we have one application install at one spoke which need to access from other spoke location.
So kindly suggest how to achive this .
Dmvpn for spoke to spoke
Thank you.
Joseph W. Doherty
Generally, spoke to spoke works even with hub to spoke topologies.  Of course, such traffic must transit the hub.  If that's what you're trying to avoid, as mentioned by the other poster, DMVPN (at least the latter variants) can construct tunnels spoke to spoke.  There are considerations using this feature.
It might also be possible to construct/configure another (temporary) tunnel for the (direct) spoke to spoke communication.  This may be better than using something like DMVPN's feature if there's only one pair of spokes you wish to interconnect.  DMVPN would be better if you wanted to allow any spoke to communicate (directly) with any another spoke.
