Showing results forĀ
Search instead forĀ
Did you mean:Ā
Issues Sending Fax out PRI
marcus.ramon
i have a setup of an existing functional VoIP network using a PRI for outbound and inbound communication
There is a fax machine connected to a router on a fxo card which is setup to route to our primary voice router to send outbound faxes
This setup was functional up until a few days ago when our telco upgraded the equipment in our DMARC room.
i am unsure if this is a configuration issue and I am having a hard time determining the cause. any input and help is greatly appreciated.
when attempting to send a fax i get a busy tone then get disconnected
below are the configuration of our routers and attached are debug readouts from both routers capturing the logs from an attempted outbound fax
Fax Machine <Connects to fxo 1/0/2 on>  FaxRTR <Routes to> PRI-RTR <then out to telco>
Configurations
FAX Router IP:192.168.77.8
voice-card 0
no dspfarm
voice-card 1
no dspfarm
voice rtp send-recv
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/0/2
description Fax Machine
voice-port 1/0/3
dial-peer voice 30 pots
destination-pattern 7111
port 1/0/2
dial-peer voice 7111 voip
description To Voice Gateway
destination-pattern .T
session target ipv4:192.168.77.2
dtmf-relay h245-alphanumeric
codec g711ulaw
num-exp 6484... 4...
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
max-ephones 42
max-dn 90
PRI Router IP:192.168.77.2
voice-port 0/0/0:23
dial-peer voice 911 pots
destination-pattern 911
port 0/0/0:23
prefix 911
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
port 0/0/0:23
dial-peer voice 20 pots
destination-pattern 8T
fax rate disable
port 0/0/0:23
dial-peer voice 100 voip
preference 2
destination-pattern 3...
session target ipv4:192.168.78.2
codec g711ulaw
dial-peer voice 22 pots
destination-pattern 92603355
port 0/0/0:23
forward-digits 7
dial-peer voice 101 voip
destination-pattern 4...
codec g711ulaw
dial-peer voice 23 voip
preference 1
session target ipv4:192.168.78.4
codec g711ulaw
dial-peer voice 25 voip
destination-pattern 6484...
dial-peer voice 12 pots
destination-pattern 22222
dial-peer voice 24 voip
preference 1
codec g711ulaw
dial-peer voice 125 voip
destination-pattern 5206484159
progress_ind setup enable 3
session target ipv4:10.10.1.110
dtmf-relay h245-signal
codec g711ulaw
fax rate 14400
no vad
dial-peer voice 126 voip
destination-pattern 5206484107
codec g711ulaw
fax rate 14400
no vad
description To Fax machine
session target ipv4:192.168.77.8
codec g711ulaw
dial-peer voice 1001 voip
destination-pattern 520.......
codec g711ulaw
max-ephones 42
max-dn 90
from your logs, I conclude that you are in the Tucson, AZ area ? Just asking because if you were in Australia, a different g711 codec could be used, or the Telco could have switched codecs (they switch from g711alaw to g711ulaw sometimes).
Either way, try to change the fax protocol to version 3 (keep in mind that you cannot use 'cisco' as fallback with version 3:
fax protocol t38 version 3 ls-redundancy 0 hs-redundancy 0 fallback none
