Issues with async connections to con 0
chrisayres
hi I have a few routers in a lab and have async connections to their con 0 port for a 3745 with an 8 port async card.
the config in the lines and con 0's is as documented on CCO.
When i am telnetted thru the 3745 onto the con 0's I keep getting spurious text displayed eg see below sho ip ospf nei
Neighbor ID Pri State ighbor ITime Pri s Interface
1.1.1.1 1 FULL/DR 00:01:44 10.10.1.1 Serial0/1
Lab_Router3_Real4#sho ip ospf nei
Neighbor ID Pri State Dead Time Address Interface
1.1.1.1 1 FULnterface 00:01:43 10.10.1.1 Serial0/1
Lab_Router3_Real4#
this is happening on all lines
any ideas
Harold Ritter
Try configuring "no exec" under the async tty ports on the 3745 as follow. It should fix the issue.
line x y
no exec
Hope this helps,
i have already tied that see below
line 65 95
exec-timeout 0 0
no exec
