Issues with room network
WVerga
I have a Gigabit internet connection, but not receiving that connection through my Cisco Router & Switch.
I have placed both the Router & Switches "sh run", "sh int br" & "cdp neighbor"
Fios router nor showing in cdp (as far as i know)
Network works but only getting around 100mb speeds, not gb speed
a 1941 router has a throughput of, as far as I recall, somewhere around 50MB, so you will never, ever be able to get anything even close to 1 Gigabit.
luis_cordova
Hi @WVerga
I have detected two things that could be limiting your speed.
1 In the router you have limited the speed of the interface to 100mb
2 On the switch, the interfaces are fastethernet, which only reaches 100mb
You could change the speed in the router and connect your pc directly to that interface, thus avoiding that the switch is limiting the speed for the type of interface.
