Hi As we know, if bgp policy changed, we need to use command to clear it as the below command. But sometimes I found people do not use the command. Can you tell in what situation, we do not need to use the clear command?
clear bgp ipv4 unicast 6.4.8.13 soft
For example:
the original config has:
as-path-set FILTER
ios-regex '_1_'
When I add the below one more ios-regex, do you think we need bgp clear command? Thank you
ios-regex '_12_'
