It does not work GRE tunnel over IPSec
Sergey Prishchepa
Between the two networks should be set up encryption. The task of trying to solve with the help of VPN IPSec. But the problem with EIGRP, always in debug I see:
% CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (Ip) vrf / dest_addr = / 224.0.0.10, src_addr = 10.10.10.14, prot = 88
Set up a GRE tunnel, but the messages were. Help please. Here are the configs.
R1
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key KEY_VPN address 10.10.10.14
crypto ipsec transform-set TS_VPN esp-des esp-md5-hmac
crypto map MAP_VPN 10 ipsec-isakmp
set peer 10.10.10.14
set transform-set TS_VPN
match address ACL
interface Tunnel0
ip address 10.10.10.41 255.255.255.252
tunnel source GigabitEthernet0/0.2
tunnel destination 10.10.10.14
interface GigabitEthernet0/0
ip address 10.10.11.11 255.255.255.248
ip flow ingress
ip nat inside
ip virtual-reassembly in
standby 0 ip 10.10.11.13
standby 0 priority 150
standby 0 preempt
ip policy route-map INTERNET-MAP
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/0.2
encapsulation dot1Q 294
ip address 10.10.10.13 255.255.255.252
crypto map MAP_VPN
router eigrp 205
network 10.0.38.0 0.0.0.15
network 10.10.11.8 0.0.0.7
network 10.10.10.12 0.0.0.3
ip route 0.0.0.0 0.0.0.0 213.130.27.193
ip access-list extended ACL
permit ip any any
permit gre any any
permit eigrp any any
permit icmp any any
R2
hash md5
crypto isakmp key KEY_VPN address 10.10.10.13
set peer 10.10.10.13
match address ACL
interface Tunnel0
ip address 10.10.10.42 255.255.255.252
tunnel destination 10.10.10.13
ip address 10.10.10.14 255.255.255.252
crypto map MAP_VPN
router eigrp 205
network 10.0.0.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 10.10.10.13
permit ip any any
permit gre any any
permit icmp any any
21 Replies 21
Thanks, i found a bug in the ACL now VPN is up, but EIGRP does not work.
I see on R2:
R1
hash md5
match address ACL
interface Tunnel0
ip flow ingress
ip nat inside
standby 0 preempt
load-interval 30
duplex auto
speed auto
crypto map MAP_VPN
router eigrp 205
ip route 0.0.0.0 0.0.0.0 213.130.27.193 track 3
permit gre host 10.10.10.13 host 10.10.10.14
R2
hash md5
match address ACL
interface Tunnel0
no ip address
duplex auto
speed auto
no mop enabled
crypto map MAP_VPN
router eigrp 205
network 10.0.0.0
ip route 0.0.0.0 0.0.0.0 Tunnel0
permit gre host 10.10.10.14 host 10.10.10.13
hi Sergery,
It seems that summarizationn is enable under your eigrp process.
please do the following:
go under your eigrp 205 and type "no auto"
Terence
Now you have to decide how you want to run your routing. There you have two routing-domains:
1) public routing
Thats where you make sure that your crypto-endpoints can reach each other. In your case you need to make sure that 10.10.10.13 can reach 10.10.10.14. As they are directly connected, no extra configuration is needed. But if your Endpoints are remote (i.e. reachalbe over the Internet) then you probably have just a static default-route or BGP with your provider. But you never have the same routing-process as the inner routing inside your tunnel because that could give you recursive routing.
2) The tunnel-routing
With that you make sure, that the remote network is reachable through the tunnel. There you can use static routing as well, or you can use dynamic routing.
Your routing-setup is mixed up. On R1 you have EIGRP on the public interface and on the tunnel, on R2 you have EIGRP and static routing on the tunnel.
How to solve that best:
- On R1 enable EIGRP only on the tunnel-interface
- On R2 also enable EIGRP only on the tunnel and remove the static default-route through the tunnel.
Thank EIGRP works. What is the default route should be on the R2? But now the problem with dhcp relay, hosts not receive dhcp-adress through R2, if we set the static everything works.
R1
hash md5
match address ACL
interface Tunnel0
ip flow ingress
ip nat inside
standby 0 preempt
load-interval 30
duplex auto
speed auto
crypto map MAP_VPN
router eigrp 205
passive-interface GigabitEthernet0/0.2
R2
hash md5
match address ACL
interface Tunnel0
no ip address
duplex auto
speed auto
no mop enabled
crypto map MAP_VPN
interface GigabitEthernet0/1
ip address 10.10.18.1 255.255.255.0
ip helper-address 10.11.10.2
ip helper-address 10.11.10.3
router eigrp 205
network 10.0.0.0
I don't see a network 10.11.10.x on your R1, so probably it's a remote network? Then you have to make sure that R1 learns that network through EIGRP.
I'm sure.
D        10.11.10.0/24
           [90/28672] via 10.10.11.9, 19:22:13, GigabitEthernet0/0
10.10.11.9 it's ASA, for 10.10.18.0/24 permit ip any.
If anyone is interested. Finished off the problem - for dhcp relay on the router must be close to the customer include the dhcp service. Thank you all for your help.
