It does not work GRE tunnel over IPSec
Sergey Prishchepa
Between the two networks should be set up encryption. The task of trying to solve with the help of VPN IPSec. But the problem with EIGRP, always in debug I see:
% CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (Ip) vrf / dest_addr = / 224.0.0.10, src_addr = 10.10.10.14, prot = 88
Set up a GRE tunnel, but the messages were. Help please. Here are the configs.
R1
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key KEY_VPN address 10.10.10.14
crypto ipsec transform-set TS_VPN esp-des esp-md5-hmac
crypto map MAP_VPN 10 ipsec-isakmp
set peer 10.10.10.14
set transform-set TS_VPN
match address ACL
interface Tunnel0
ip address 10.10.10.41 255.255.255.252
tunnel source GigabitEthernet0/0.2
tunnel destination 10.10.10.14
interface GigabitEthernet0/0
ip address 10.10.11.11 255.255.255.248
ip flow ingress
ip nat inside
ip virtual-reassembly in
standby 0 ip 10.10.11.13
standby 0 priority 150
standby 0 preempt
ip policy route-map INTERNET-MAP
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/0.2
encapsulation dot1Q 294
ip address 10.10.10.13 255.255.255.252
crypto map MAP_VPN
router eigrp 205
network 10.0.38.0 0.0.0.15
network 10.10.11.8 0.0.0.7
network 10.10.10.12 0.0.0.3
ip route 0.0.0.0 0.0.0.0 213.130.27.193
ip access-list extended ACL
permit ip any any
permit gre any any
permit eigrp any any
permit icmp any any
R2
hash md5
crypto isakmp key KEY_VPN address 10.10.10.13
set peer 10.10.10.13
match address ACL
interface Tunnel0
ip address 10.10.10.42 255.255.255.252
tunnel destination 10.10.10.13
ip address 10.10.10.14 255.255.255.252
crypto map MAP_VPN
router eigrp 205
network 10.0.0.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 10.10.10.13
permit ip any any
permit gre any any
permit icmp any any
21 Replies 21
Roman Rodichev
Level 7
Level 7
Сергей, поменяй ACL на:
permit ip host 10.10.10.13 host 10.10.10.14
и
permit ip host 10.10.10.14 host 10.10.10.13
Я так понимаю на R1
а на R2
Попробовал не помогает.
Чем это отличается от
permit ip any any?
А как проверить ходит ли траффик через GRE?
terrencepayet
Hi Sergey,
You should never use "permit ip any any" in a crypto map access-list.
With a "permit ip any any" statement, the router will ONLY accept encrypted
traffic coming in on your Gigabit interface 0/0.2(because everything is a match
for "permit ip any any". This is what is breaking your eigrp.
Your getting the "Rec'd packet not an IPSEC packet" error because your
access-list ACL matches everything (permit ip any any). This means
everything received on Gigabit interface into the router must be encrypted traffic,
or it will be rejected. I believe that the multicast eigrp traffic
originating from gigabit interface will never be encrypted.
Please apply the config suggested by Roman.
Is that for learning-purpose or do you want to use it in production? For production I wouldn't use anything else anymore then virtual tunnel interfaces:
http://www.cisco.com/en/US/partner/docs/ios/12_3t/12_3t14/feature/guide/gtIPSctm.html
Once the ACL is left only to:
and
that
R1#sh cry sess
Crypto session current status
Interface: GigabitEthernet0/0.2
Session status: UP-IDLE
Peer: 10.10.10.14 port 500
  IKEv1 SA: local 10.10.10.13/500 remote 10.10.10.14/500 Active
  IKEv1 SA: local 10.10.10.13/500 remote 10.10.10.14/500 Inactive
  IPSEC FLOW: permit ip host 10.10.10.13 host 10.10.10.14
        Active SAs: 0, origin: crypto map
  IPSEC FLOW: permit 47 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
debug
Jul  7 07:49:52.103: ISAKMP (1028): received packet from 10.10.10.14 dport 500 sport 500 Global (R) QM_IDLE
Jul  7 07:49:52.103: ISAKMP: set new node 744776555 to QM_IDLE
Jul  7 07:49:52.103: crypto_engine: Decrypt IKE packet
Jul  7 07:49:52.103: crypto_engine: Generate IKE hash
Jul  7 07:49:52.103: ISAKMP:(1028): processing HASH payload. message ID = 744776555
Jul  7 07:49:52.103: ISAKMP:(1028): processing SA payload. message ID = 744776555
Jul  7 07:49:52.103: ISAKMP:(1028):Checking IPSec proposal 1
Jul  7 07:49:52.103: ISAKMP: transform 1, ESP_DES
Jul  7 07:49:52.103: ISAKMP:   attributes in transform:
Jul  7 07:49:52.103: ISAKMP:      encaps is 1 (Tunnel)
Jul  7 07:49:52.103: ISAKMP:      SA life type in seconds
Jul  7 07:49:52.103: ISAKMP:      SA life duration (basic) of 3600
Jul  7 07:49:52.103: ISAKMP:      SA life type in kilobytes
Jul  7 07:49:52.103: ISAKMP:      SA life duration (VPI) of  0x0 0x46 0x50 0x0
Jul  7 07:49:52.103: ISAKMP:      authenticator is HMAC-MD5
Jul  7 07:49:52.103: ISAKMP:(1028):atts are acceptable.
Jul  7 07:49:52.103: IPSEC(validate_proposal_request): proposal part #1
Jul  7 07:49:52.103: IPSEC(validate_proposal_request): proposal part #1,
  (key eng. msg.) INBOUND local= 10.10.10.13:0, remote= 10.10.10.14:0,
    local_proxy= 10.10.10.13/255.255.255.255/0/0 (type=1),
    remote_proxy= 10.10.10.14/255.255.255.255/0/0 (type=1),
    protocol= ESP, transform= NONE  (Tunnel),
    lifedur= 0s and 0kb,
    spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x0
Jul  7 07:49:52.103: Crypto mapdb : proxy_match
src addr     : 10.10.10.13
dst addr     : 10.10.10.14
protocol     : 0
src port     : 0
dst port     : 0
protocol     : 0
src port     : 0
dst port     : 0
Jul  7 07:49:52.103: map_db_find_best did not find matching map
Jul  7 07:49:52.103: IPSEC(ipsec_process_proposal): proxy identities not supported
Jul  7 07:49:52.103: ISAKMP:(1028): IPSec policy invalidated proposal with error 32
Jul  7 07:49:52.103: ISAKMP:(1028): phase 2 SA policy not acceptable! (local 10.10.10.13 remote 10.10.10.14)
Jul  7 07:49:52.103: ISAKMP: set new node -894830763 to QM_IDLE
Jul  7 07:49:52.103: ISAKMP:(1028):Sending NOTIFY PROPOSAL_NOT_CHOSEN protocol 3
spi 822122880, message ID = 3400136533
Jul  7 07:49:52.103: crypto_engine: Encrypt IKE packet
Jul  7 07:49:52.103: ISAKMP:(1028): sending packet to 10.10.10.14 my_port 500 peer_port 500 (R) QM_IDLE
Jul  7 07:49:52.103: ISAKMP:(1028):Sending an IKE IPv4 Packet.
Jul  7 07:49:52.103: ISAKMP:(1028):purging node -894830763
Jul  7 07:49:52.103: ISAKMP:(1028):deleting node 744776555 error TRUE reason "QM rejected"
Jul  7 07:49:52.103: ISAKMP:(1028):Node 744776555, Input = IKE_MESG_FROM_PEER, IKE_QM_EXCH
Jul  7 07:49:52.103: ISAKMP:(1028):Old State = IKE_QM_READY  New State = IKE_QM_READY
Jul  7 07:49:58.363: ISAKMP:(1027):purging node 1361484197
Jul  7 07:49:58.367: ISAKMP:(1027):purging node -978575193
Jul  7 07:50:06.279: %DUAL-5-NBRCHANGE: EIGRP-IPv4 205: Neighbor 10.10.10.14 (GigabitEthernet0/0.2) is down: retry limit exceed
ed
Jul  7 07:50:08.359: IPSEC(key_engine): request timer fired: count = 2,
  (identity) local= 10.10.10.13:0, remote= 10.10.10.14:0,
    local_proxy= 0.0.0.0/0.0.0.0/47/0 (type=4),
    remote_proxy= 0.0.0.0/0.0.0.0/47/0 (type=4)
Jul  7 07:50:08.851: IPSEC(sa_request): ,
  (key eng. msg.) OUTBOUND local= 10.10.10.13:500, remote= 10.10.10.14:500,
    remote_proxy= 0.0.0.0/0.0.0.0/47/0 (type=4),
    protocol= ESP, transform= esp-des esp-md5-hmac  (Tunnel),
    lifedur= 3600s and 4608000kb,
Jul  7 07:50:08.851: ISAKMP: set new node 0 to QM_IDLE
Jul  7 07:50:08.851: SA has outstanding requests  (local 49.63.137.200 port 500, remote 49.63.137.228 port 500)
Jul  7 07:50:08.851: ISAKMP:(1028): sitting IDLE. Starting QM immediately (QM_IDLE      )
Jul  7 07:50:08.851: ISAKMP:(1028):beginning Quick Mode exchange, M-ID of 64585526
Jul  7 07:50:08.851: ISAKMP:(1028):QM Initiator gets spi
Jul  7 07:50:08.851: crypto_engine: Generate IKE hash
Jul  7 07:50:08.851: crypto_engine: Encrypt IKE packet
Jul  7 07:50:08.851: ISAKMP:(1028): sending packet to 10.10.10.14 my_port 500 peer_port 500 (R) QM_IDLE
Jul  7 07:50:08.851: ISAKMP:(1028):Sending an IKE IPv4 Packet.
Jul  7 07:50:08.851: ISAKMP:(1028):Node 64585526, Input = IKE_MESG_INTERNAL, IKE_INIT_QM
Jul  7 07:50:08.851: ISAKMP:(1028):Old State = IKE_QM_READY  New State = IKE_QM_I_QM1
Jul  7 07:50:08.855: ISAKMP (1028): received packet from 10.10.10.14 dport 500 sport 500 Global (R) QM_IDLE
Jul  7 07:50:08.855: ISAKMP: set new node 549659124 to QM_IDLE
Jul  7 07:50:08.855: crypto_engine: Decrypt IKE packet
Jul  7 07:50:08.855: crypto_engine: Generate IKE hash
Jul  7 07:50:08.855: ISAKMP:(1028): processing HASH payload. message ID = 549659124
Jul  7 07:50:08.855: ISAKMP:(1028): processing NOTIFY PROPOSAL_NOT_CHOSEN protocol 3
spi 1230905296, message ID = 549659124, sa = 0x313F8860
Jul  7 07:50:08.855: ISAKMP:(1028): deleting spi 1230905296 message ID = 64585526
Jul  7 07:50:08.855: ISAKMP:(1028):deleting node 64585526 error TRUE reason "Delete Larval"
Jul  7 07:50:08.855: ISAKMP:(1028):deleting node 549659124 error FALSE reason "Informational (in) state 1"
Jul  7 07:50:08.855: ISAKMP:(1028):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
Jul  7 07:50:08.855: ISAKMP:(1028):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETEJul  7 07:49:52.103: ISAKMP (1028): received packet from 10.10.10.14 dport 500 sport 500 Global (R) QM_IDLE
protocol     : 0
src port     : 0
dst port     : 0
protocol     : 0
src port     : 0
dst port     : 0
ed
the ACLs would be better the following way:
permit gre host 10.10.10.13 host 10.10.10.14
and
permit gre host 10.10.10.14 host 10.10.10.13
Then you can test the connectivity with cleartext packets.
and
did not help
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_conn_vpnips/configuration/15-0m/sec-ipsec-virt-tunnl.html
thanks, will read
what does this error?
Hi Sergey,
Please turn off auto summarization under your EIGRP process.
HTH.
Terence
In the debugging it seems that your crypto-ACLs are not working as they should. Can you please show the actual config?
Terrence Payet: auto summarization is turn off.
R1
permit gre host 10.10.10.13 host 10.10.100.14
R2
or all of the configuration?
Why in the show crypto session two?
Hi Sergey,
Please send all of the config. As suggested  by karsten, it seems theres an issue with your crypto map ACL.
terence
