iWAN - APIC-EM
tporembski
I can't seem to get a clear answer as to APIC-EM and its use with iWAN.  DO I need to run APIC-EM in order for Iwan to function?  Does the APIC-EM control daya to day operation  and any troubleshooting of the Iwan solution?  Can I use APIC-EM long with traditional CLI troubleshooting and configuration?
Thank you
Paul Chapman
Level 4
Level 4
Hi -
APIC-EM is not required.  You can build IWAN by hand.  The problem is that if you want to "convert" to an APIC-EM controlled IWAN, the APIC will entirely overwrite the router configurations.  So you really want to choose 1 or the other during the design and test phases of your project.
PSC
Hello Paul,
Even we have the same issue, we have build the whole setup by hand. Now we want to move to APIC-EM for sites to get deployed. Can you tell me any updates made on this. Can we integrate APIC-EM with existing Master Controller and HUB's??
Satya.Mothukuri
Unfortunately there is not way to integrated APIC-EM IWAN app to your existing topology.
Best
