karthik (support for router config)
i need to access the host in  MPLS network from the internet
we have more than 35 branches in india, all are interconnected with MPLS network. These links are connected with our core router 2811. We using 1841 for internet line. Our requirment is to enable port forwarding technique to get the video conferencing machine from one our branch through internet.
Hi karthik ,
                   How is Internet supported for all this 35 Branches , do you have common internet gateway ?? / each branches has got individual internet gateway .
                You can do Port NATING /Static NAT (better do static NAT because VC uses random user defined port )on your internet router for your Internal host/VC unit .  If you have common internet gateway for all 35 location , ensure Qos is done from your Branch office where you have VC unit to your head office where you have internet gateway .
Let me know if you need further support
Sandy
This discussion has been reposted from Cisco Support Community Olympics Trivia to the WAN, Routing and Switching community.
