L2 Metro EThernet Security Best Practice
Hassan Chalabi
what is the best security practice to secure the layer 2 Metro Ethernet connections between branches and HQ, your input is highly appreciated.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Depends whether you trust your MetroE provider, such that you consider the MetroE circuit like your own internal links.  If you do, treat it like an internal link.  If not, run encryption over it and block all non-expected traffic.
