L2 QOS
emadehsan
Dear All,
here is my network topology:
LAN ( A ) -- R1 --- R2 ---LAN(B)
---LAN (C)
the link between R1 and R2 is wireless.
it has some variation in bit rate transfers.
my lan b is my gold customer and i want to use more bandwidth that lan c
i have choosed L2 QOS..
any hint or solution please?
guruprasadr
Level 7
Level 7
HI,
You can use Rate-limit Feature to limit the Bandwidth for each LAN.
Pls let us know your requirement in brief.
Do Rate all Helpful Posts.
Best Regards,
Guru Prasad R
dear prasad
acctulaly my link between two wirelesses
are not stable, sometime the bit rate is less that 6Mbps, but the acctually throughput is about 36Mbps
because of this variation , i need a qos solution that be flexible with this issue
i think on L2 qos..
any other solution do u have?
