ISDN Test-Call not possible on CISCO878
s.steiner
our company works for dsl-carriers in Germany. One part of our work is the test and refurbishment of cpe-routers like 876, 878 or 18xx. During the test of several 878 we determined problems with isdn test-call.
Configuration :
interface BRI0
no ip address
encapsulation hdlc
isdn switch-type basic-net3
isdn point-to-point-setup
isdn send-alerting
isdn sending-complete
ISDN-Status :
Router#sh isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 64, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
Router#
Test-Call :
Router#isdn test call int bri 0 33
Debug Q.931 and isdn events :
*Mar 1 04:04:32.591: ISDN BR0 EVENT: UserIdle: callid 0x8002 received ISDN_CALL (0x0)
*Mar 1 04:04:32.591: ISDN BR0 **ERROR**: process_bri_call: Outgoing call id 0x8002 blocked
*Mar 1 04:04:32.591: ISDN BR0 **ERROR**: UserIdle: process_bri_call failed on call to 33
*Mar 1 04:05:02.591: ISDN BR0 EVENT: UserIdle: callid 0x8002 received ISDN_HANGUP (0x1)
*Mar 1 04:05:02.591: ISDN BR0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0x8002, event 0x5 ces 1
*Mar 1 04:05:02.591: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x8002 calltype 1 HOST_QUERY_RESPONSE
The router does not setup the call, neither being connected to an isdn-line of a german telekom switch nor connected to an isdn-pbx. A CISCO876 with the same IOS and setup works very well. Additionally, I couldn't find the debug messages anywhere on the CCO or in the web. I have tested 5 878, all showing the same symptoms.
Is there anybody who can help me or do I need to open a ticket with the TAC ?
Best regards,
Stephan
9 Replies 9
EPHRAIM MANI
Level 3
Level 3
Hi s.steiner
Request to post teh q.921 debug for further analysis.
Thanks EM
Kindly post all rate if its informative.
here is the output of the requested debugs :
ISDN BRI0 interface
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Router#deb isdn q931
debug isdn q931 is ON.
Router#deb isdn ev
debug isdn event is ON.
Router#deb isdn q921
debug isdn q921 is ON.
Router#
*Mar 1 00:09:03.191: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:03.191: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:03.191: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:03.207: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:03.223: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:03.223: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=64 nr=0
Router#isdn te
*Mar 1 00:09:13.223: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:13.227: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:13.227: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:13.243: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=64 nr=0st call int bri 0 333
Router#
*Mar 1 00:09:20.555: ISDN BR0 EVENT: UserIdle: callid 0x8001 received ISDN_CALL (0x0)
*Mar 1 00:09:20.555: ISDN BR0 **ERROR**: process_bri_call: Outgoing call id 0x8001 blocked
*Mar 1 00:09:20.555: ISDN BR0 **ERROR**: UserIdle: process_bri_call failed on call to 333
*Mar 1 00:09:23.243: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:23.263: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:23.267: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:23.271: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:33.267: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:33.267: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:33.267: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:33.283: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:33.299: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:33.299: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:43.299: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:43.303: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:43.307: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:43.315: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:43.331: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:43.331: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:50.555: ISDN BR0 EVENT: UserIdle: callid 0x8001 received ISDN_HANGUP (0x1)
*Mar 1 00:09:50.555: ISDN BR0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0x8001, event 0x5 ces 1
*Mar 1 00:09:50.555: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x8001 calltype 1 HOST_QUERY_RESPONSE
*Mar 1 00:09:53.331: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:53.331: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:53.331: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:53.347: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=64 nr=0
*Mar 1 00:09:53.363: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Mar 1 00:09:53.363: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=64 nr=0
Router#u all
All possible debugging has been turned off
Router#
I also did some research in the feature navigator. It tells me that there is no actual image available for the 878 with ISDN-functionality. What's that ? It has a BRI-interface and is identical with the 876 with the exception of the dsl-interface. Does it mean that 878 routers do not support ISDN-backup ????
Best regards,
Stephan
Hi Stephan
As per the data sheet Cisco 878 supports out of band management with the isdn port and i dont think you can make use of the same for dial back solution.
But its the other way with Cisco 876 which supports both isdn dial backup as well as out of band management with the isdn port.
So i dont think you will be able to execute any isdn dial commands since it doesnt support the feature..
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a976.html
regds
thank you for this information. It's very astonishing, but it seems to be a fact, that this ISDN interface on a 878 is not usable for backup purposes.
Best regards,
Stephan
Very strange indeed.However, the data sheet indicated that for backup on the 876, an advance enterprise service image is needed. I would try to load that one and see if something changes.
I will try this. But in the downloadcenter, you have to coose 876 for the download of this featureset. When you choose 878, this image won't be available.
Reg.,
Stephan
Correct, however the filename reflects that even "enterprise image" is applicable to all 87x. So it's worth a try. Let us know how it goes.
Ok, also the enterprise-image doesn't work :
Router#sh ver
Cisco IOS Software, C870 Software (C870-ADVENTERPRISEK9-M), Version 12.4(11)T3, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 12-Jul-07 06:58 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI3, RELEASE SOFTWARE
Router uptime is 4 minutes
System returned to ROM by reload
System image file is "flash:c870-adventerprisek9-mz.124-11.T3.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 878 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
Processor board ID FHK111716LV
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
128K bytes of non-volatile configuration memory.
28672K bytes of processor board System flash (Intel Strataflash)
ISDN BRI0 interface
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Router#sh deb
The following ISDN debugs are enabled on all DSLs:
debug isdn error is ON.
debug isdn q931 is ON. (filter is OFF)
Router#
*Mar 1 00:18:11.163: ISDN BR0 EVENT: UserIdle: callid 0x8003 received ISDN_CALL (0x0)
*Mar 1 00:18:11.163: ISDN BR0 **ERROR**: process_bri_call: Outgoing call id 0x8003 blocked
*Mar 1 00:18:11.163: ISDN BR0 **ERROR**: UserIdle: process_bri_call failed on call to 33
*Mar 1 00:18:41.163: ISDN BR0 EVENT: UserIdle: callid 0x8003 received ISDN_HANGUP (0x1)
*Mar 1 00:18:41.163: ISDN BR0 EVENT: isdn_hangup: Hangup call to call id 0x8003 ces = 1
*Mar 1 00:18:41.163: ISDN BR0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0x8003, event 0x5 ces 1
*Mar 1 00:18:41.163: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x8003 calltype 1 HOST_QUERY_RESPONSE
I'll give up now ;-).
Best regards,
Stephan
Hi Stephan
Appreciate your courtesy in getting back to the forum with your findings :-).
regds
