L2L error codes
jrmdynamac
OK, I finally got the VPN tunnel between 2 asa 5505's up and running, but I have some error codes on the initiator side that I can not figure out.
Here is what I get on errors:
5Jun 06 201115:17:59713257Phase 1 failure: Mismatched attribute types for class Group Description: Rcv'd: Group 1 Cfg'd: Group 2
3Jun 06 201115:17:59713048IP = XXX.XXX.199.210, Error processing payload: Payload ID: 1
3Jun 06 201115:17:59713902IP = XXX.XXx.199.210, Removing peer from peer table failed, no match!
4Jun 06 201115:17:59713903IP = XXX.XXXX.199.210, Error: Unable to remove PeerTblEntry
I have looked at the Crypto transforms on both sides, and they match just fine as far has the DH ID code, Group Number and the encryption. The remote side however, does not have any of there errors.
Is this something that I have skipped over, or missed that I should be looking for?
The IP address that is listed above is not in my static addresses, not sure where theose are coming from. I believe that they are outside public IP's.
Thanks - Jon
   You can use ACL to deny this IP address comming in WAN interface and permit anything else.
HTH,
Toshi
  The error indicates that IKE proposal is mismatched(Phase I). It seems that XXX.XXXX.199.210 was trying to connect to your device.
HTH,
Toshi
Not sure what this IP is pointing to. I only have 1 IP adress in that range and it is pointed to the outside interface of the ASA. I continually get errors on this IP. IS there a way that I can block it from attempting to connect?
-Jon
HTH,
Toshi
