L2TP Tunnel between LNS and RAS
Bharat Negi
Can anyone help:
- how can I form a L2TP tunnel between RAS and LNS without a PRI connection to RAS. I want to simulate a L2TP tunnel and get it authenticated locally on LNS.
- Once L2TP tunnel is formed and authenticated, how can I associate to the respective VRF.
BSN
Not applicable
You should configure VPDN group mode on the RAS.On the LNS you should disable authenticion on the interface terminating ppp session
http://www.cisco.com/en/US/docs/ios/12_1/dial/command/reference/drdrlimo.html
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080509cba.html
Thanks for the reply. I have pasted the configs of RAS and LNS below. Can you suggest changes. This is the curren configuration and not working. PPPoE session is getting established but not L2TP tunnel.
RAS:
vpdn-group 1
request-dialin
protocol l2tp
initiate-to ip 10.10.10.1 >>>Loopback of LNS
local name RAS
l2tp tunnel password 0 cisco
vpdn-group 2
accept-dialin
protocol pppoe
virtual-template 2
username cisco password 0 cisco
interface Loopback100
ip address 10.10.10.2 255.255.255.255
interface GigabitEthernet0/0 >>Conn to Fa2/1/1 of LNS
ip address 10.10.20.1 255.255.255.0
pppoe enable
interface Virtual-Template2
ip unnumbered Loopback100
peer default ip address pool test
ppp authentication chap callin
ip local pool test 10.10.20.2 10.10.20.10
ip route 0.0.0.0 0.0.0.0 gig 0/0
LNS:
vpdn-group 10
accept-dialin
protocol l2tp
virtual-template 1
terminate-from hostname RAS2
source-ip 10.10.10.1
ip address 10.10.10.1 255.255.255.255
interface FastEthernet2/1/1 >>Conn to Gig0/0 of RAS
ip address 10.10.20.2 255.255.255.0
interface Virtual-Template1
ip route 0.0.0.0 0.0.0.0 FastEthernet2/1/1
