L2tp VPN -no access to internal vlans after Policy based Routing added
davidfield
Level 3
Level 3
Hello All,
I'm hoping you can assist with come guidance on what I could be doing wrong.  I have a site where we had an L2tp vpn operating and all worked ok.  The client asked us to connect a 2nd Internet connection up to afor dedicated streaming traffic.  I setup PBR and now the L2TP vpn cannot connect to the devices on the inside.  I can however ping the Interfaces on the Router.
I'm missing something fundamental on how PBR has affected this setup.  Any ideas appreciated
Config excerpts
PRB
interface Vlan1
ip address 192.168.100.254 255.255.255.0
ip pim sparse-dense-mode
ip nat inside
ip virtual-reassembly in
ip policy route-map Route_to_G
interface Vlan100
no ip address
interface Vlan101
ip address 192.168.101.254 255.255.255.0
ip nat inside
ip policy route-map Route_to_BT
interface Vlan102
ip address 192.168.102.254 255.255.255.0
ip nat inside
interface Vlan103
ip address 192.168.103.254 255.255.255.0
ip nat inside
Outside interfaces
interface GigabitEthernet8
ip address 192.168.2.253 255.255.255.0
ip nat outside
ip inspect CCP_LOW out
ip tcp adjust-mss 1452
duplex auto
speed auto
crypto map outside_map
interface Vlan254
ip address 192.168.1.253 255.255.255.0
ip nat outside
route-map Route_to_G permit 10
match ip address 110
set ip next-hop 192.168.1.254
route-map Route_to_BT permit 10
match ip address 120
set ip next-hop 192.168.2.254
ip nat inside source list 110 interface Vlan254 overload
ip nat inside source list 120 interface GigabitEthernet8 overload
access-list 1 permit any
access-list 110 deny ip 192.168.100.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 110 deny ip 192.168.100.0 0.0.0.255 192.168.102.0 0.0.0.255
access-list 110 deny ip 192.168.100.0 0.0.0.255 192.168.103.0 0.0.0.255
access-list 110 permit ip 192.168.100.0 0.0.0.255 any
access-list 120 deny ip 192.168.101.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 120 deny ip 192.168.102.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 120 deny ip 192.168.103.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 120 permit ip 192.168.101.0 0.0.0.255 any
access-list 120 permit ip 192.168.102.0 0.0.0.255 any
access-list 120 permit ip 192.168.103.0 0.0.0.255 any
access-list 120 permit ip 192.168.105.0 0.0.0.255 any
L2tp Config
vpdn enable
vpdn-group L2TP
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
interface Loopback1
description loopback for IPsec-pool
ip address 192.168.105.1 255.255.255.255
ip nat inside
interface Virtual-Template1
ip unnumbered Loopback1
peer default ip address pool l2tp-pool
ppp authentication ms-chap-v2 VPDN_AUTH
ppp ipcp dns 8.8.8.8
ip local pool l2tp-pool 192.168.105.10 192.168.105.20
Dave
davidfield
Level 3
Level 3
Ok so for those that hit the same issue it is due to PBR bypassing the route table.
I was able to setup PBR for the traffic on the interface I needed to direct to a specific WAN port.  The remaining traffic goes out the default WAN interface and therefore can remove the PBR route map for those interfaces.  L2tp access kicked in again so all looks ok.
