L2TP vs GRE
satpot1981
Hi all,
Can anyone clearly explain that what is the difference between L2TP and GRE tunnel?
I am  trying to understand where these protocol are used and why we use L2TP instead of GRE in some cases and vice versa.
smehrnia
Level 7
Level 7
Hi Murat
GRE is a simple IP packet encapsulation protocol. a GRE tunnel is used when packets need to be sent from one network to another, without being parsed or treated like IP packets by any intervening routers. a GRE tunnel interface comes up as soon as it is configured and it stays up as long as there is a valid tunnel source address or interface which is up.
L2TP is a tunneling protocol (used to support VPNs) that allows multiplexing of multiple PPP sessions between two IP-connected endpoints, and a control protocol for dynamically establishing and maintaining the emulation of these PPP sessions. This is very different than GRE.
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
aain
has anyone configured L2TP on cisco 9K nexus
