NX-OS OSPF Redestribute Static-Route With Route-map filter not work
Bill lo
Hi Community
I have trouble with OSPF route-filter ;
the situation as below:
we add some static-route on N9504
ip route 192.168.128.0/24 x.x.x.x.x
ip route 192.168.151.0/24 x.x.x.x.x
ip route 192.168.153.0/24 x.x.x.x.x
Before add those route, there are Route-map for filter the static redistribute in OSPF
route-map red_static_list permite 10
match ip address red_static_list
ip access-list red_static_list
permit ip 10.x.x.x.0/24 any
permit ip 124.x.x.0/24 any
router ospf 10
route-id x .x.x.x
redistribute static route-map red_static_list
even though the Route-map is already on there , but it's not work, the ospf redistribute all static-router to other ospf neithbor.
On downstream neighbor (N5K) ,  show ip route  can see the 192.168.128.0/24  route , and show ip ospf database external 192.168.128.0 . display the advertise-router id is the N9504
the Nx-OS  version is 9.2(3)
permit ip 10.x.x.x.0/24 any <- remove any
permit ip 124.x.x.0/24 any <- remove any
then try again
the access-list only use source to filter the prefix
13 Replies 13
then try again
Hi MHM
Maybe you are right ,  from : Troubleshooting Cisco Nexus Switches and NX-OS
Interior Gateway Protocol (IGP) Network Selection
When ACLs are used for the IGP network selection during redistribution, the source
fields of the ACL are used to identify the network, and the destination fields identify
the smallest prefix length allowed in the network range.
And i also find the Bug:NXOS: routing redistribution route-map with ACL will allow any prefix (CSCtt04685)
It's seem not good ideal for using ACL to match route.
Yes the acl for route filter have many limit so instead can you try use prefix list.
Prefix list is so simple and accurate for route filter
Do you have 'redistribure static' on the OSPF process?
Yes , the redistribute static is work , "show ip ospf database " on N9504  , can see there are all static-route in it as type-5 route.
even though the route not match the ACL , still appear in the Database.
Try re-applying the redistribute static command with route map.
-David
Hi David
thank you reply
will take a try when prepare the LAB environment for reproduce situation.
thx
Bill
Mahmoud Elsoury
Use 'redistribute static subnets'
Hi  Mahmoud
there are no "subnet"  to use , when redistribute route into OSPF:
redistribute [bgp asn | direct | eigrp process-tag | isis process-tag | ospf process-tag | rip process-tag | static] route-map route-map-name
also thax your reply.
Bill
Hello
router ospf 10
route-id x .x.x.x
redistribute static route-map red_static_list subnets
Try and append the subnets keyword so subnetted prefixes are advertised
Kind Regards
Paul
Hi Paul
 NX-OS  don't have the keyword "subnet" to use,
and my trouble is filter route not work , instead of missing-route.
thank you reply
Bill
Hello
Can you confirm if the current default routes are specifying a next-hop ip address or a connected interface, if its a connected interface then the redistribute command should state -  direct
redistribute direct route-map xxxx
Kind Regards
Paul
