03-26-2015 08:24 AM - edited 03-05-2019 01:06 AM
Hi... Im trying to configure a l2tpv3 tunnel between a ASR1001 and a C3925. Im not able to find the way to activate te command pseudowire-class on the 3925. I try installing a license for security and data, but still nothing... Any clues?
Solved! Go to Solution.
03-27-2015 08:05 AM
03-26-2015 07:30 PM
L2TP feature is available on IP Base license.
Check it out here: http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Minh
03-27-2015 05:59 AM
I installed the base license, installed data and security demo license and nothing. Im not able to configure neither pseudowire-class nor xconnect because the commands are simply not available. Could be a thing of the ios...
03-27-2015 07:43 AM
LOL
Do you want to solve the issue?
If so, please provide "show ver" + configuration you are trying to apply (and CLI output that doesn't allow you to configure the command).
03-27-2015 07:50 AM
03-27-2015 07:56 AM
Hello.
L2TPV3 requires DATA license that is not enabled on your box.
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html
Please enable/install it and reload the box.
03-27-2015 07:59 AM
03-27-2015 08:05 AM
03-27-2015 08:35 AM
with license boot module c3900e technology-package datak9 and a reload command, the license starts to be in use...
03-27-2015 03:33 AM
Hello.
Could you provide the configuration you are trying to apply and the error message.
Please attach "show ver".
03-27-2015 05:51 AM
It looks like the command pseudowire-class is not accepted by the 3925E or the ios version 15.2(M)4. I dont get error messages because im not able to configure the layer 2 tunnel.
03-27-2015 05:55 AM
Could you provide the configuration you are trying to apply and the output from CLI?
