L2TPv3 tunnel between Cisco IOS and ASR 9000 IOS-XR
narainarun
Hi All,
I am trying to establish L2TPv3 VLAN-to-VLAN based pseudowire between Cisco NPE-G2 and ASR 9001 routers but could not bring the pseudowire up and end to end reachability.
Below are the configuration:
ASR:
RP/0/RSP0/CPU0:LAB-ASR1#sh run l2vpn
Tue Sep 10 22:50:02.204 UTC
l2vpn
pw-class test
  encapsulation l2tpv3
   protocol l2tpv3 class test
   ipv4 source 10.10.10.103
   transport-mode vlan
xconnect group l2tpv3
  p2p lab1-2
   interface GigabitEthernet0/0/0/1.101
   neighbor 10.20.0.3 pw-id 100
    pw-class test
RP/0/RSP0/CPU0:LAB-ASR1#sh run l2tp
Tue Sep 10 22:50:10.190 UTC
l2tp-class test
authentication
password 7 095F470F00544541
RP/0/RSP0/CPU0:LAB-ASR1#sh run int gi 0/0/0/1.101
Tue Sep 10 22:50:18.071 UTC
interface GigabitEthernet0/0/0/1.101 l2transport
encapsulation dot1q 101
NPE-G2:
l2tp-class test
authentication
password 7 071C284A57584B56
pseudowire-class test
protocol l2tpv3 test
ip local interface Loopback0
CE1-NPEG2#sh run int gi 0/3.101
Building configuration...
Current configuration : 106 bytes
interface GigabitEthernet0/3.101
encapsulation dot1Q 101
xconnect 10.10.10.103 100 pw-class test
end
CE1-NPEG2#
Have anyone tried L2TPv3 between IOS and ASR 9001 and working?
thanks in advance
Arun
NUNO PIMENTA
did you ever solve this issue?
I'm trying to do the same, without any luck.
l2vpn
pw-class AC
   protocol l2tpv3 class AC
   ipv4 source 192.168.255.236
   transport-mode vlan
  p2p LINX
   interface TenGigE0/0/0/0.210
   neighbor ipv4 192.168.255.232 pw-id 210
    pw-class AC
Tue Jan 28 10:39:36.310 UTC
Legend: ST = State, UP = Up, DN = Down, AD = Admin Down, UR = Unresolved,
        SB = Standby, SR = Standby Ready, (PP) = Partially Programmed
XConnect                   Segment 1                       Segment 2
Group      Name       ST   Description            ST       Description            ST
l2tpv3     LINX       DN   Te0/0/0/0.210          UP       192.168.255.232 210    DN
Nuno
Hi Arun/Nuno,
As I just got update from Cisco ASR 9000 doesn't support l2tpv3 over IPv4 please try it over IPv6.
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.3/lxvpn/configuration/guide/lesc43p2ps.html#wp1298172
Regards, Pok.
