L2VPN configuration and licence requirements for ISR4431
esraaagimbilgin
Hi All,
We need to know how we can do L2VPN configuration and licence requirements for ISR4431 .
Yes, you can do MPLS with your ISR4431 (LDP, L3VPN, L2VPN -AToM & VPLS-, etc). Also, you can do L2TPv3 (Layer 2 Tunneling using IP transport).
In order to be able to enable to configure such features, you need the Application Experience (AX) license activated (formerly called the 'Data' license).
The information can be found in this document.
Cisco 4000 Series Integrated Services Routers Data Sheet
For the configuration, what specific L2VPN flavor are you interested in?
Hello, I have similar issue. I have ordered an ISR4431-K9 router, but I don't know if WAAS-RTU-1300 and ISRWAAS-RTU-1300 is included or is a part of the L-SL-44-APP-K9= Application license. Is it enough if I order the L-SL-44-APP-K9= for my router?
