L3 SVI and L2 VLANS
abc1235
Hallo,
This is a rather basic question but I will ask it anyway I copied the working running configs from a faulty 891 Cisco router to another one. Initially, it didn't work (clients were not getting an IP even though the VLAN was pingable) and on troubleshooting, I saw that the L3 SVIs were configured but the VLANs weren't. I configured the L2 VLANs but on checking the running configs, they were not there. I went ahead to make more changes on trial basis and finally the clients got an IP address. I am convinced that it was after the creation of the L2 VLANs would have fixed the problem, but I would like a confirmation of the same. Is that the case? Must L2 VLANs be created first before the SVIs?
Thanks.
Martin L
Yes, You Must have L2 VLANs in database before the SVIs?  Or SVI vlan x will stay down until you add vlan x.  Also, there must be an active port in vlan x for SVI x to be up up. you can change this default behavior with
no switchport autostate
or
switchport autostate exclude
command. This port can be access port or a trunk but for sure vlan x must exist in vlan database (stored in flash of a device).
Regards, ML
**Please Rate All Helpful Responses **
5 Replies 5
frknl
Running-config
doesn't cover vlan database, so without
interface vlan x
ip add x.x.x.x/prefix-length
command it will not work.
for the SW you can start with L3 SVI or L2 VLAN, AND for router I think it same you can config the SVI then this SVI is down until you add L2 VLAN to router which turn UP.
Martin L
or
Regards, ML
abc1235
Thank you all for the responses. I now understand where the problem was
Hello
L3 switch in particular , you need to create the L2 vlan as its not created as/when you create its L3 svi equivalent
Kind Regards
Paul
