(LAB) Cannot ping from internal LANs to WAN interface on Nexus 9k
jnetworx
Hello All,
I'm currently labbing in EVE-NG with a Nexus 9k and some ASAs
I'm able to ping from within each LAN behind the 9k to the external WAN interface on the same 9k, however I cannot get traffic to forward to the next hop whilst having a route to the next hop configured
On the same note, I'm unable to ping from an external IP to within the internal LAN
Nexus 9k config (DGFW for LAN via sub-interfaces) as follows:
interface Ethernet1/1
no switchport
no shutdown
interface Ethernet1/1.10
encapsulation dot1q 10
ip address 192.168.10.1/24
no shutdown
interface Ethernet1/1.20
encapsulation dot1q 20
ip address 192.168.20.1/24
no shutdown
interface Ethernet1/1.30
encapsulation dot1q 30
ip address 192.168.30.1/24
no shutdown
interface Ethernet1/2
no switchport
ip address 10.0.0.2/30
no shutdown
0.0.0.0/0, ubest/mbest: 1/0
*via 10.0.0.1, [1/0], 00:36:38, static
10.0.0.0/30, ubest/mbest: 1/0, attached
*via 10.0.0.2, Eth1/2, [0/0], 00:48:37, direct
10.0.0.2/32, ubest/mbest: 1/0, attached
*via 10.0.0.2, Eth1/2, [0/0], 00:48:37, local
192.168.10.0/24, ubest/mbest: 1/0, attached
*via 192.168.10.1, Eth1/1.10, [0/0], 00:51:02, direct
192.168.10.1/32, ubest/mbest: 1/0, attached
*via 192.168.10.1, Eth1/1.10, [0/0], 00:51:02, local
192.168.20.0/24, ubest/mbest: 1/0, attached
*via 192.168.20.1, Eth1/1.20, [0/0], 00:50:38, direct
192.168.20.1/32, ubest/mbest: 1/0, attached
*via 192.168.20.1, Eth1/1.20, [0/0], 00:50:38, local
192.168.30.0/24, ubest/mbest: 1/0, attached
*via 192.168.30.1, Eth1/1.30, [0/0], 00:50:24, direct
192.168.30.1/32, ubest/mbest: 1/0, attached
*via 192.168.30.1, Eth1/1.30, [0/0], 00:50:24, local
Next hop router (ASA) config: (current licensing I have access to does not allow OSPF to be enabled, hence the correlating networks not being added to the OSPF table)
interface GigabitEthernet1
ip address 10.0.0.1 255.255.255.252
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet2
ip address 10.0.0.13 255.255.255.252
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet3
ip address 10.0.0.5 255.255.255.252
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet4
no ip address
shutdown
negotiation auto
no mop enabled
no mop sysid
router ospf 10
router-id 1.1.1.1
network 10.0.0.0 0.0.0.3 area 0
network 10.0.0.4 0.0.0.3 area 0
network 10.0.0.12 0.0.0.3 area 0
10.0.0.0/8 is variably subnetted, 8 subnets, 2 masks
C 10.0.0.0/30 is directly connected, GigabitEthernet1
L 10.0.0.1/32 is directly connected, GigabitEthernet1
C 10.0.0.4/30 is directly connected, GigabitEthernet3
L 10.0.0.5/32 is directly connected, GigabitEthernet3
O 10.0.0.8/30 [110/2] via 10.0.0.14, 01:13:52, GigabitEthernet2
[110/2] via 10.0.0.6, 01:13:44, GigabitEthernet3
C 10.0.0.12/30 is directly connected, GigabitEthernet2
L 10.0.0.13/32 is directly connected, GigabitEthernet2
O 10.0.0.16/30 [110/2] via 10.0.0.14, 01:13:52, GigabitEthernet2
O 172.16.0.0/16 [110/2] via 10.0.0.6, 01:13:44, GigabitEthernet3
S 192.168.10.0/24 is directly connected, GigabitEthernet1
I have a static route pointing from the ASA to one of the internal sub-interfaces and vice-versa, however pings continue to fail
Any help would be greatly appreciated
0 Replies 0
