Lab: Routers multi-area
Telim
Hi, Guys, I'm trying to build this lab but I got really confused. I had to do it and do it again and I cannot.
any help and explanation would be much appreciated.
Thanks a lot in advance.
find the revised Packet Tracer file. This provides end to end connectivity.
I have opened the lab. What is the specific problem you are running into ?
I don't think I did the multi area right. I cannot ping between the
routers.
I need to be able to ping from router 7 to router 4.. the ends ones
Thanks a lot. I can see what I was doing wrong.
