LAB: Unable to ping internally
Vking02
Hi Team,
Hope someone can assist me.
I currently have a EVE-NG lab I am trying to complete, but having issues.
I am unable to ping the inside interface on a Cisco device from my Home network.
I have a static route on my home route pointing to the subnet (192.168.11.x/28) in question (see Image cisco1 for static route)
This is the config of the cisco device
interface GigabitEthernet0/0
ip address 192.168.11.2 255.255.255.240
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
ip address dhcp
ip nat outside
duplex auto
speed auto
media-type rj45
ip nat inside source list 11 interface GigabitEthernet0/3 overload
access-list 11 permit 192.168.11.0 0.0.0.15
access-list 11 permit 192.168.22.0 0.0.0.255
access-list 11 permit 192.168.33.0 0.0.0.255
access-list 11 permit 192.168.44.0 0.0.0.255
access-list 11 permit 192.168.55.0 0.0.0.255
access-list 11 permit 192.168.66.0 0.0.0.255
control-plane
GigabitEthernet0/0 192.168.11.2 YES NVRAM up up >>>> points to a FW
GigabitEthernet0/1 unassigned YES NVRAM administratively down down
GigabitEthernet0/2 unassigned YES NVRAM administratively down down
GigabitEthernet0/3 172.16.10.24 YES DHCP up up <<<< points to ISP router
NVI0 192.168.11.2 YES unset up up
What is confusing me is, I am able to ping from the FW outside interface (192.168.11.3) to 8.8.8.8 fine
admin@PA-VM> ping source 192.168.11.3 host 8.8.8.8
PING 8.8.8.8 (8.8.8.8) from 192.168.11.3 : 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=2 ttl=116 time=19.1 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=116 time=14.1 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=116 time=14.6 ms
^C
--- 8.8.8.8 ping statistics ---
4 packets transmitted, 3 received, 25% packet loss,
This is the network design - see attached image, cisco2
What am i missing and where am i going wrong?
Thank you in advance.
16 Replies 16
Johnson_Mo
Can you please share the configs on PA firewall? I have GNS3 LAB where I want to connect cisco 7200 with PA and the link wont come up on the subnet. tried static route, tried OSPF, still wont o=come up.
Johnson_Mo
can you please share the configs on Palo Alto site? I am trying to connect cisco 7200 with PA on the same network, the link wont come up and can not ping each other. I enabled ping for the PA interface as well.
thanks
