06-24-2011 05:41 AM - edited 03-04-2019 12:48 PM
I want to create a redundant ring topology.
Switch A <-> Switch B
Switch B <-> Switch C
Switch C <-> Switch A
I`m using gigabit interfaces, and want 2Gbps backbone capasaty.
What will be the best setup here?
Thought about using LACP and RSTP, but can they function togheter, or should I only use LACP?
Wery happy if some can explain a configuration example
06-24-2011 06:33 AM
These are 2 different protocols.By default PVST+ is the spanning-tree solution enabled on switches to solve L2 loops problem but you can change to RPVST+( Cisco implementation of Rapid STP) or MSTP.
If you want to bundle links you can use PagP(Cisco proprietary) or LACP or manual bundling.
So RPVST+ and LACP GEC is no problem.
But don't forget depending on etherchannel load-balancing technique and your traffic flows you may end using only one of the bundled interface and so still max out at 1 Gig.
For configs, take a look here
etherchannels:
STP:
Regards.
Alain.
06-24-2011 07:00 AM
Thank you.
Why? Wont it use both interfaces as long as they are up an running?
06-24-2011 07:28 AM
perpaal a écrit:
Thank you.
No load-balancing algorithms take into effect src-mac or src-ip or src-dst mac or src-dst ip and on some higher end platforms even the TCP/UDP port.
It is platform dependent. http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
Regards.
Alain.
