Latency and Delay during DB Replication
Ibrahim Jamil
Level 6
Level 6
Hi Folks
I Have 4 Mbps MPLS Link betwwen Two Sites , I Received Compain fron the Data Base Administrator ,there is a Delay and Latency appears on Logs when the dataBase Replucations occurs
How to start Troubleshoot and Vrify this Issue,Pls Helps , this Issue makes me Headache
6 Replies 6
johnlloyd_13
Level 9
Level 9
Do bi-directional ping and traceroute to see where congestion/latency occurs
Hi John!
How do i do Do bi-directional ping and traceroute to see where congestion/latency occurs?
vmiller
Level 7
Level 7
A few other things to understand.
1. What are the terms of your agreement with yhe MPLS provider?
    a. Is all your bandwidth guaranteed, there is generally some sort of service plan for traffic volume.
2. Is there QOS involved ?
   a. This relates to item 1 the questions would be are you marking the replication traffic with any QOS? and what is the provider doing or not doing with       marked or unmarked traffic.
My own experience is that replication traffic runs better with a larger MTU. Is this something you and your provider can negotiate ?
Hi Vineller
Please Explain the Below
1)What do y mean by "there is generally some sort of service plan for traffic volume"?
2)no qos involved
3)what do u mean by "My own experience is that replication traffic runs better with a larger  MTU"
Carriers (at least in the US) provide different service levels for mpls customers. for example a carrier may only guarantee 50 percent of the bandwidth for your ef marked traffic. the res (in their mind 0 is elegible to be dropped.
Bigger frames generally provides better throughput. but it requires mtu adjustment along the path.
How to do the below test:
1) Do bi-directional ping and traceroute to see where congestion/latency occurs
2) can y explain this breifly,i didnt understand it:
"Bigger frames generally provides better throughput. but it requires mtu adjustment along the path"
