layer 2 between 2 sites over wires only mpls
carl_townshend
Hi guys
we have an mpls wires only network where we manage the ce routers, so just run bgp to our provider and can advertise whatever we want. We use ISR 4k routers
If i wanted to extend vlans between 2 of my sites over this, what is the best technology to achieve it? L2TPv3?  How about evpn? Could i do evpn without vxlan?
I would also like to lab this in cml, anyone got a lab for an evpn setup ?
many thanks
Carl
7 Replies 7
For evpn ypu need to contact SP
For l2tpv3 aince you have already l3vpn run with sp then you can config l2tpv3 xconnect over l3vpn.
MHM
R4#show running-config
Building configuration...
Current configuration : 1934 bytes
! Last configuration change at 01:39:30 UTC Wed Jul 10 2024
version 15.2
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
pseudowire-class class
encapsulation l2tpv3
ip local interface Loopback0
interface Loopback0
ip address 4.4.4.4 255.255.255.255
interface Loopback10
ip address 44.44.44.44 255.255.255.255
interface Loopback100
ip address 144.144.144.144 255.255.255.255
interface FastEthernet0/0
ip address 10.0.0.4 255.255.255.0
duplex full
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/1
no ip address
speed auto
duplex auto
no keepalive
xconnect 5.5.5.5 45 encapsulation l2tpv3 pw-class class
interface Serial3/0
no ip address
shutdown
serial restart-delay 0
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
interface GigabitEthernet4/0
no ip address
shutdown
negotiation auto
router bgp 100
bgp log-neighbor-changes
network 4.4.4.4 mask 255.255.255.255
network 44.44.44.44 mask 255.255.255.255
neighbor 10.0.0.1 remote-as 200
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R5#show run
*Jul 10 01:40:45.299: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 1761 bytes
! Last configuration change at 01:40:45 UTC Wed Jul 10 2024
version 15.2
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
ip address 5.5.5.5 255.255.255.255
ip address 11.0.0.5 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
speed auto
duplex auto
no keepalive
xconnect 4.4.4.4 45 encapsulation l2tpv3 pw-class class
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
no ip address
shutdown
negotiation auto
router bgp 400
network 5.5.5.5 mask 255.255.255.255
neighbor 11.0.0.3 remote-as 300
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R1#show run
R1#show running-config
*Jul 10 01:40:49.791: %LDP-5-NBRCHG: LDP Neighbor 200.0.0.2:0 (1) is UP
Current configuration : 2270 bytes
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip vrf RED
rd 1:100
route-target export 1:100
route-target import 1:100
no ip domain lookup
no ipv6 cef
mpls label mode vrf RED protocol bgp-vpnv4 per-vrf
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip vrf forwarding RED
ip address 10.0.0.1 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
ip address 100.0.0.1 255.255.255.0
mpls ip
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
no ip address
shutdown
negotiation auto
router ospf 100
network 1.1.1.1 0.0.0.0 area 0
network 100.0.0.0 0.0.0.255 area 0
router bgp 200
neighbor 3.3.3.3 remote-as 300
neighbor 3.3.3.3 ebgp-multihop 255
neighbor 3.3.3.3 update-source Loopback0
neighbor 3.3.3.3 next-hop-unchanged
address-family vpnv4
neighbor 3.3.3.3 activate
neighbor 3.3.3.3 send-community extended
exit-address-family
address-family ipv4 vrf RED
redistribute static
neighbor 10.0.0.2 remote-as 100
neighbor 10.0.0.2 activate
neighbor 10.0.0.4 remote-as 100
neighbor 10.0.0.4 activate
exit-address-family
no ip http server
ip route vrf RED 144.144.144.144 255.255.255.255 10.0.0.4
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3#show ru
R3#show running-config
Current configuration : 2127 bytes
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip vrf RED
rd 1:100
no ip domain lookup
no ipv6 cef
interface Loopback0
ip address 3.3.3.3 255.255.255.255
ip address 11.0.0.3 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
ip address 200.0.0.3 255.255.255.0
mpls ip
no ip address
shutdown
negotiation auto
router ospf 100
network 3.3.3.3 0.0.0.0 area 0
network 200.0.0.0 0.0.0.255 area 0
router bgp 300
neighbor 1.1.1.1 remote-as 200
neighbor 1.1.1.1 ebgp-multihop 255
neighbor 1.1.1.1 update-source Loopback0
neighbor 1.1.1.1 next-hop-unchanged
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 send-community extended
exit-address-family
neighbor 11.0.0.5 remote-as 400
neighbor 11.0.0.5 activate
exit-address-family
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Hello
VXLAN sounds like the best alternative additionally EVPN if you wish to route between those vlans
Kind Regards
Paul
Giuseppe Larosa
Hello @carl_townshend ,
I think L2TPv3 is your best choice of course the limitation is that thisis  a L2 point to point transport service.
Consider @MHM Cisco World 's post for an example of configuration
Hope to help
Giuseppe
carl_townshend
Thanks for the responses, what if we wanted to extend multiple vlans using L2TPv3 ? would you need multiple pseudowire classes? any examples?
Also VXLAN EVPN was also mentioned, is one better than the other ?
No for class you can use same class but add
interworking vlan
And multi vlan ypu need in CE route config subinterface and use xconnect for each subinterface with different VC value' VC value is the label and it must be unique.
MHM
Hello
review here mpls L2 vpns as @Giuseppe Larosa noted options available would be based on platform dependency
Kind Regards
Paul
