Layer 2 HWIC 4 Port routing?
accurisit
Hi All,
I'm looking for some urgent help please.
I have a Cisco 1901 router with 2 onboard Gigabit Ethernet ports that are configured as a BVI due to an unusual config with the ISP (it works!).
I also need to route/NAT to from 2 or 3 other subnets and requested my reseller to provide a 4 port HWIC which they did.
I tried to apply ip addressing to the FastEthernet ports only to receive a message stating it wasn't possible on a Layer 2 port.
I therefore created a vlan and assigned it an ip address and subnet mask from a subnet I wished to route traffic through. I assigned the vlan to the Layer 2 FastEthernet port but cannot ping or route through it.
Is this even possible or am I banging my head against a very solid wall.
Simon...
14 Replies 14
Jon Marshall
Simon
They are L2 ports only but you should be able to do the vlan setup that you have tried. Might be an idea to post the config together with details of what test(s) you have run.
Jon
Configuration:
bridge irb
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
bridge-group 1
interface FastEthernet0/0/0
description SS7
switchport access vlan 10
interface FastEthernet0/0/1
switchport access vlan 20
interface FastEthernet0/0/2
shutdown
interface FastEthernet0/0/3
shutdown
interface Vlan1
no ip address
interface Vlan10
ip address 10.150.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan20
ip address 10.30.1.253 255.255.255.0
ip nat inside
interface BVI1
description **** WAN Link to ISP IP Network ****
ip address a.b.c.b 255.255.255.192
ip nat outside
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool lan a.b.c.a a.b.c.a netmask 255.255.255.192
ip nat inside source list 5 pool lan overload
ip nat inside source static 10.30.1.32 a.b.c.d
ip nat inside source static 10.30.1.5 a.b.c.e
ip nat inside source static 10.30.1.42 a.b.c.f
ip route 0.0.0.0 0.0.0.0 87.198.157.1
ip route 87.198.157.4 255.255.255.255 a.b.c.g
ip route 87.198.157.6 255.255.255.255 a.b.c.g
ip route 87.198.157.8 255.255.255.255 a.b.c.g
ip route 87.198.157.9 255.255.255.255 a.b.c.g
ip route 87.198.157.10 255.255.255.255 a.b.c.g
ip route 87.198.157.11 255.255.255.255 a.b.c.g
ip route 87.198.157.20 255.255.255.255 a.b.c.g
ip route 87.198.157.22 255.255.255.255 a.b.c.g
ip route 87.198.157.45 255.255.255.255 a.b.c.g
access-list 5 permit 10.150.1.0 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
TESTS
Ping 10.30.1.253 from router itself.
Tried to ping 10.30.1.253 from 10.30.1.0 subnet.
Tried to route through 10.30.1.253 from 10.30.1.0 subnet.
All tests failed.
Simon...
Can you post output of "sh ip int brief".
I'm assuming you created the vlan at L2 ?
Jon
Thanks Jon.
interface FastEthernet0/0/0 & interface FastEthernet0/0/1 are the 2 in question.
As you've probably guessed I'm masking the Public IPs with a.b.c.x.
Output:
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         unassigned      YES manual up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  up                    up
FastEthernet0/0/0          unassigned      YES unset  down                  down
FastEthernet0/0/1          unassigned      YES unset  up                    up
FastEthernet0/0/2          unassigned      YES unset  administratively down down
FastEthernet0/0/3          unassigned      YES unset  administratively down down
Vlan1                      unassigned      YES manual up                    down
Vlan20                      10.30.1.253     YES manual up                    down
Vlan10                     10.150.1.1      YES manual up                    down
NVI0                       unassigned      NO  unset  up                    up
BVI1                       a.b.c.b    YES manual up                    up
Simon
The problem is your vlan interfaces are up/down ie. they are not up so they won't respond to anything.
Did you create the vlan at L2 and not just the L3 vlan interface ie.
either -
router(config)# vlan
or
router# vlan database
router(...)# vlan
sorry i can never remember which one it is on these routers !
Jon
Not sure if this helps:
Router#sh spanning-tree vlan 20
VLAN20 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 32768, address 68ef.bd9a.af63
  Configured hello time 2, max age 20, forward delay 15
  We are the root of the spanning tree
  Topology change flag not set, detected flag not set
  Number of topology changes 0 last change occurred 04:37:27 ago
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
  Timers: hello 0, topology change 0, notification 0, aging 300
Port 2 (FastEthernet0/0/1) of VLAN20 is broken (Port Type Mismatch)
   Port path cost 19, Port priority 128, Port Identifier 128.2.
   Designated root has priority 32768, address 68ef.bd9a.af63
   Designated bridge has priority 32768, address 68ef.bd9a.af63
   Designated port id is 128.2, designated path cost 0
   Timers: message age 1, forward delay 14, hold 0
   Number of transitions to forwarding state: 0
   BPDU: sent 8318, received 0
Simon
Can you post -
"sh vlan database" or "sh vlan brief"
Can you modify fa0/0/1 to be -
int fa0/0/1
switchport mode access
spanning-tree portfast
then shutdown fa0/0/1 and vlan 20 and then do a "no shut" on each interface.
Jon
Jon,
Got this message and as this connects directly into a switch will it cause an issue?
Router(config-if)#spanning-tree portfast
%Warning: portfast should only be enabled on ports connected to a single host.
Connecting hubs, concentrators, switches,  bridges, etc.to this interface
when portfast is enabled, can cause temporary spanning tree loops.
Use with CAUTION
%Portfast has been configured on FastEthernet0/0/1 but will only
have effect when the interface is in a non-trunking mode.
I can now ping 10.30.1.253 from the router but not from anywhere else or to anywhere else on the 10.30.1.0 subnet.
Router#sh int vlan 20
Vlan20 is up, line protocol is up
  Hardware is EtherSVI, address is 68ef.bd9a.af63 (bia 68ef.bd9a.af63)
  Internet address is 10.30.1.253/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 0/255
  Keepalive not supported
  Last input 00:11:31, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1 packets input, 92 bytes, 0 no buffer
     Received 1 broadcasts, 0 runts, 0 giants, 0 throttles
     70 packets output, 4744 bytes, 0 underruns
     0 output errors, 2 interface resets
     0 unknown protocol drops
Simon
Simon
What is connected into fa0/0/1 ? is it a switch or is it your laptop. If it is a switch then you should not have "spanning-tree portfast". I assumed it was the laptop.
Also if it is a switch and your laptop is connected to that switch how have you configured the switch ? Can you post config and indicate which port is the link to fa0/0/1 and which your laptop is connected to.
Where are the other clients in the same vlan connected to ?
Jon
Jon,
Connected to a switch.
Also if it is a switch and your laptop is connected to that switch how have you configured the switch?
I'm connected over Telnet via the BVI1.
Laptop remote.
Connected to the switch.
Simon
Simon
Then need to see the switch config.
Have you set the default-gateway of all the other clients in that vlan to be the fa0/0/1 ip address ?
Are all the ports for the clients configured to be in vlan 20 ?
Presumably you are trying to ping the other clients ? - do you have personal firewalls on the PC's that could be blocking the pings ?
Jon
This has now been resolved. Not sure if it's the textbook answer but it works.
switchport trunk native vlan 20
switchport mode trunk
interface Vlan20
ip nat inside
Thanks for all of your assistance Jon
Simon
So the port on the switch connecting to fa0/0/1 was configured as a trunk link. That would explain your STP output.
Thanks for letting me know you fixed it.
Jon
